<!-- from fixya rte -->How do I add a second cooling fan - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,256 Answers
Cold pads work very well and are very inxpensive
Posted on Nov 20, 2014
2007 vue 2.2 4 cylinder How do you get all the coolant out. removed radiator drain plug coolant cap and only got 1 gallon out pan- system was full manual showed a little over 2 gallon capacity
Cooling System Draining and Filling (Static Fill)
Draining Procedure
    Warning! In order to avoid personal injury, do not remove the cap or open the cooling system drains from a hot system. Allow the system to cool first.
    Click to Enlarge
    ImportantA 7.6 liter (8 qt) coolant container will be needed.
  1. Place the coolant container under the radiator drain **** located at the bottom of the right radiator end tank.
  2. Open the drain **** and drain the coolant. A small amount of coolant will drain from the system.
  3. Click to Enlarge
  4. Remove the surge tank cap from the surge tank and the coolant will drain from the system.
  5. Click to Enlarge
  6. For LE5 and LAT vehicles, if the engine block needs to be drained, a drain bolt is located near the bottom of the water pump assembly.
  7. Inspect the coolant.
  8. Follow the appropriate procedure based on the condition of the coolant.
  9. • Normal in appearance--follow the filling procedure.
    • Discolored--follow the flush procedure. Refer to Coolant System Flushing .
    Filling Procedure
      Caution! All entrapped air must be purged from the powertrain cooling system before the final coolant level can be determined. Proper coolant level is critical to avoid engine damage.
      ImportantThe vehicle must be level when filling the cooling system.
    1. Slowly add a mixture of 50/50 DEX-COOL antifreeze and clean water to the coolant surge tank. Fill the cooling system as indicated below:
    2. • For LE5/LAT vehicles when the engine block is not drained, add 3.5 liters (3.7 qts)
      • For LE5/LAT vehicles when the engine block is drained, add 6 liters (6.3 qts)
      • For LZ4/LY7 vehicles, add 5 liters (5.3 qts)
    3. Start the engine and check for leaks.
    4. Run the engine and cycle the vehicle from idle to 3,000 RPM in 30 second intervals until the engine cooling fan comes ON, the engine cooling fan turns ON at approximately 102°C (216°F). Repeat this process twice before the engine is turned OFF.
    5. Return the engine to idle, and idle for 30 seconds, then turn the engine OFF.
    6. Allow the vehicle to cool, before adding additional coolant.
    7. ImportantThe level in the surge tank will return into the cold fill range once the vehicle cools.
    8. Add additional coolant to the surge tank until the level is approximately 13 mm (0.5 in) above the surge tank seam.
    9. Install the coolant surge tank cap.
    10. Hope this helps.
May 26, 2018 | Cars & Trucks
The location of a 2002 chevy cavalier cooling fan sensor
The cooling fan is controlled by the PCM - powertrain control module through a relay ! There is no cooling fan sensor , there is a coolant temperature sensor ! This coolant temperature sensor is an input to the engine computer , if there were a problem wit the sensor the check engine light would be on .
Cooling Fan Control
The engine cooling fan system consists of one cooling fan and one relay. The relay is powered by the battery positive voltage circuit and controlled by a switched ground from the powertrain control module (PCM).
During operation, the PCM supplies the ground path for the cooling fan relay through the cooling fan relay control circuit. This energizes the cooling fan relay coil, closes the relay contacts, and supplies battery positive voltage from the cooling fan fuse through the cooling fan motor supply voltage circuit to the cooling fan. The cooling fan motor is grounded through its own ground circuit.
The PCM commands the fan on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
A/C is requested and vehicle speed is below 100 km/h (62 mph) with A/C pressure above 1413 kPa (205 psi).
Vehicle speed is less than 8 km/h (5 mph) for more than 750 seconds. The fan will turn off when vehicle speed is greater than 8 km/h (5 mph) for more than 20 seconds.
Jun 12, 2015 | 2002 Chevrolet Cavalier
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
My 1996 Nissan Maxima only overheats when on incline but I can turn the heat on & it cools down immediately.
Could be the radiator fan. Running the heater adds a second source of getting rid of heat in the coolant. Is the radiator fan running when it is hot ? Are you sure the cooling system is full ?
Oct 08, 2012 | 1996 Nissan Maxima
1999 grand prix gtp second cooling fan will not turn on
How hot is the vehicle running? The second cooling fan is programmed to operate only, like the first cooling fan, at a predetermined engine temperature. It varies by model, if I remember correctly however I think it is 226F for the fan to turn on, and at some point if that does not begin working the second fan will turn on.
May 20, 2012 | 1999 Pontiac Grand Prix
How can I set fan speed manually to balance temperature in house?
Basements are supposed to be cooler . after all they are basically a cave .
Oct 17, 2017 | Honeywell Electronic Programmable...
I have a 99 Honda Accord and the engine sounds fine as long as I am accelerating; however, as soon as Iet off the accelorator, it starts making a noise that sounds as if something is knocking against the...
First check the grade of 'Gasoline' now days they add ethanol,Which can cause engine knock, Second lift the " hood' while auto mobile has been off and cool to prevent cooling fan injury,look for any obstructions,such as a wire's harness,Third i would check catolitic converter for loose heat shield.
Sep 24, 2011 | 2000 Honda Accord
How do i add coolant to the ac
First before adding freon is the compressor and fan running? Second, is both the condenser nd evap free from dirt? Please advise, RepairUSA
Aug 30, 2007 | Samsung AW0603B Air Conditioner
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
