Question about Freezers
What is the odd chemical smell my freezer fan is blowing?
I used KILZ in the adjoining room yesterday, so I don't know if it picked up some of that, but the smell is different. Not sweet, as people have said refrigerant smells. Just a chemical smell. Food is cold but fan stays on even when I turn the freezer temp down. OLD unit.
  • 1 more comment
  • C.M. Carteaux Nov 20, 2014
    Refrigerator does NOT smell and they are both keeping proper temps.
    I had no water yesterday but freezer does not have an automatic ice maker. HOW can I get the freezer fan to cycle off without affecting fridge?
    Nothing behind the unit to check as far as fan shutoff.
  • Freezers Master
  • 16,174 Answers
If the fan wont stop then it could be the motor on the unit that is overheating. The other thing would be the defrost coil.
Posted on Nov 21, 2014
  • C.M. Carteaux Nov 21, 2014
    I unplugged it for a bit and now the fan has shut off.
Strong Odor when running
The smell is coming from the condenser heating up which should be located all around the outside of the box. When it is in pull down from being warm the condenser will get very hot and the smell would be the spray foam and any other chemicals in the vicinity heating up. When heated up to a certain point they will off gas and you may get a smell. After a little wile the smell should go away for good.
Mar 27, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Freezer started emitting a chemical smell and food is thawing.
if its a sweet sickly smell then its possibly just a relay thats burnt out,should be cheap enough to replace,its the call out thats the killer.
Mar 11, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Walk in freezer placed inside a room, condensate problems
no don't do that sounds like the drain tube going to the defrost pan is not in properly remove front grate and inspect to see if tube is off to one side if you completely seal the void that is required on operating frig's if has no air flow to cool the compressor will overheat and shorten the life or not cool properly
Sep 09, 2009 | Freezers
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Broke down after 3 years!! Any ideas on what wrong and how to fix it?
Hi Bill,
You will not like this repair at all. It is cheap and easy but usually really gross. So hold your nose and read on.
This time of year we have little visitors in our garages that like to find a warm place to cuddle up. They will crawl into the back of your freezer and find your warm compressor and start looking for places to build a house. While walking around they will eventually walk directly into the condensor fan and and usually they will not die, they will just be stuck in the fan blades. The heat that begins to build up will slowly cook the little critter and you will get a foul smell for a couple of days. Then you will notice the freezer has stopped cooling well. To repair simply remove the rat from the condensor fan and you got it fixed. In some cases the fan can burn out from the jam so you may need to replace it. I always hate to do this job, it is easy but who likes to handle a cooked rat??? Grossss.. Please dont forget to rate me and try to have a nice day.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
134 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
