Question about Home
I have a gas fireplace with logs that need replacing badly. I want to replace the logs with new ones. Company may have gone out of business.
Looked at Home Depot and Lowes. Where can I find logs with Serial # 15042 and Model # 794014?
    Problem Solver:
  • 5 Answers
Chances are you will not need to replace the logs with exact duplicates - the real concern when replacing gas logs is two-fold:
1. The electrical connection - most units use a standard 110v power source - usually connected to a single pole switch. The connection to the burner unit usually comes in the form of a small metal box with the power line from the switch connected inside, usually with 3 wires - black (hot), white (neutral), and bare or green (ground) - make sure any replacement unit is designed for 110v.
2. The gas connection - while this is something than can be done by the end consumer, the better bet is to have a HVAC professional disconnect the older unit and make the connection to the new one. The good news is that almost all gas units are designed to work with universal connectors, the bad news is that this connection needs to be completely free of defect or leaks, hence the recommendation for a HVAC pro.
Posted on Nov 20, 2014
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
My vented gas firs place keep gping into flame lift off. Hos do i fix this flame lift off. My gas log pro says i have to take the box out.??
I would suggest looking under the bottom louver of your fireplace as you have a b-vent or direct vent gas fireplace. From the looks of it alone it appears as its an early model Heat-N-Glo fireplace. If you flip down the bottom panel, where the two gold strips are at, underneath the gas valve you will find a sticker or a plate that has the model, manufacturer, and serial number. I work for a manufacturer that has been in the fireplace business for over 30 years and I'm betting $10 to a donut that is a Heat-N-Glo fireplace. Once you get the model, manufactuer, serial number, and date code sometimes you can search at www.heatnglo.com for AUTHORIZED dealers who can service your fireplace properly instead of a chimney sweep who may or may not be qualified to "trouble shoot" what is going on with the fireplace. It looks like an 8000GDV to me.
Best guess is a new pilot assembly if its a direct vent. If its a b-vent then a high limit switch might be needed as well with it cutting off that fast. It also could be a flue disconnect. Long story short I would find out the model, manufacturer, and then get on the manufacturer's website or call them to find out an AUTHORIZED servicing dealer for your fireplace. I hope this helps.
Apr 08, 2014 | Home
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Looking for user manual for Insta-Flame H20 fireplace
The Insta-Flame burner was a product of Majestic Fireplace/Vermont Castings, which went bankrupt and is no longer in business. However, Monessen Hearth, bought the gas fireplace and gas log part of the business. But, their new model numbers don't match up yours. If you could provide me with how old your fireplace is , the full Model Number and Serial Number. I may can help you.
Please advise.
Mar 23, 2011 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Slow igniting gas fireplace
vermont casting company had filed bankruptcy, company doesnt stand behind product, just attempted to get replacement parts....company states not available....may need entire new unit....i think the better business b...needs to be notified.
Dec 11, 2009 | Vermont Casting VCS4017 (NG)
Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Home Logo
64 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
