Question about Sylvania 2007-2009 Mercedes Benz S550 Headlight Bulb, 07-09 HID-D1S
How to change a headlight bulb on a 2008 Mercedes S550
    Top Expert:
  • Sylvania Master
  • 51,587 Answers
Open the hood/bonnet and look at the back of head light they are twist lock mostly twist and pull out of socket
Posted on Feb 23, 2015
Change headlight bulb touch assembly
if there the same as mine you need to push in and then down to release the spring the spring goes around a small hook get a torch to see what your doing can be fidaly to do
Jan 15, 2014 | 2007 Mercedes-Benz S550 Sedan
How to remove a Mercedes Benz gl 450 gl parking bulb in headlight
Twist counter clockwise. They can be very stubborn, don't break it.
Mar 14, 2013 | Mercedes Gl-class Gl450 Gl550 Gl320...
REPLACE HEADLIGHT 2008 SPRINTER
On some cases there are few hidden clips holding the assembly from under hood,that has to be released to remove headlight .
There are few troubleshooting help links showing how to replace car headlights,i suggest you to refer the links to solve these issue.
Click the link below:------
How to Replace a Headlight http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Low beam headlights Modification? http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html --------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a Headlight Door http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
These will help.
Thanks.
Nov 23, 2012 | 2010 Mercedes-Benz Sprinter
How do i replace the high beam headlamp on a 2008 mercedes c 300
On many Mercs, you can't get to the bulbs without having to remove the headlight. With HID lights however, it is sometimes the HID circuit which is faulty and not always the bulb itself, so be aware.
The headlights on most Mercs are located with small screws, which are not obvious, and so most people are puzzled by them.
If you can find it's locating screws and remove the light, then be careful not to handle any new bulbs with your fingers or palm. Oil from your hands can affect the life and performance of any new bulb.
Also, always use bulbs which are EXACTLY the same type as the ones you take out as Mercs are also extremely sensitive to bulb types. Even if the bulb draws an even slightly different number of amps than standard, that can be enough to either prevent them from working at all, or to start throwing fault codes up at the driver.
Nov 13, 2012 | 2008 Mercedes-Benz C 300
How to replace a taillight bulb on a S550 Mercedes?
how to change tail lights on 2007 Mercedes benz s550
Nov 23, 2011 | 2007 Mercedes-Benz S550 Sedan
I have a 2008 aveo. i took off the headlight but i can not get the plastic casing off to change the bulb.
If you are talking about the headlight casing, where the clear headlight casing connects to your back headlight casing, that isn't the way to change the light bulb, you're going to damage the seals that protect water, and humidity.
Here's a good site to visit http://wiki.answers.com/Q/How_do_you_replace_headlight_bulbs_in_Chevy_Aveo
Feb 01, 2011 | 2008 Chevrolet Aveo5
How do you remove the headlight bulb
1. Remove headlight unit
2. Disconnect headlight leads
3. Remove bulb cover
4. Remove headlight bulb holder
5. Remove headlight bulb
6. Install new headlight bulb - DO NOT TOUCH THE GLASS PART OF THE BULB!
7. Install headlight bulb holder
8. Install bulb cover
9. Connect headlight leads
10. Install headlight unit
I'm not aware of any shortcuts, nor do I believe that any steps could be changed or eliminated without re-engineering the headlight unit.
Jun 06, 2010 | 2008 Yamaha Royal Star Venture
Headlight repair on 2003 Mercedes Benz E320
how do you change left low beam bulb on 2003 mercedes e320
Mar 15, 2009 | 2003 Mercedes-Benz E-Class
Driver's side low-beam headlight out
Purchase the correct bulb, open your hood, unscrew the white retaining ring behind the non working lamp when loose turn black connection 1/4 turn counter clockwise till tabs line up pull straight back remove old bulb put on rubber gloves or BE CAUTIOUS NOT TO TOUCH NEW BULB GLASS WITH BARE FINGERS. Oils from your hands an cause bulb to heat unevenly and cause new bulb to explode in the headlight assembly
So with gloved hands open new bulb insert follow steps in reverse to reassemble. Happy Motoring
Feb 27, 2009 | 2008 Mercedes-Benz Mercedes Benz Clk Class
Sylvania 2007-2009 Mercedes Benz S550 Headlight Bulb, 07-09 HID-D1S Logo
216 people viewed this question
Top Sylvania Optics Experts
jdtech
Andrew Taylor
Andrew Taylor
Are you a Sylvania Optic Expert? Answer questions, earn points and help others
