Question about Ryobi Garden
Can't find replacement sprocket/slip ring/washer for the newer 40volt brushless chainsaw model RY40511. Ryobi website sends to ereplacementparts.com, they don't have model in their inv
Can't find replacement sprocket/slip ring/washer for the newer 40volt brushless chainsaw model RY40511. Ryobi website sends to ereplacementparts.com, they don't have model in their inventory. Tried ordering parts from RY40500, just arrived, won't fit. Sprocket busted loose and lost in September, HELP!
  • 1 more comment
  • Eugene Rounds Nov 20, 2014
    Hi Kent murphey, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Would there be a UT- number on it?
  • Kent murphey
    Kent murphey Feb 17, 2015
    Still no ry40511 model on ereplacementparts.com . Called and placed order with Ryobi, but nice man said could take months. Home Depot man said go to Home Depot Repair Center Store nearby, that they get the parts I can't. Will try that approach and let this board know.
  • Kent murphey
    By the way, in meantime had to buy EGO 56 volt brushless chainsaw, ice storm brought down tree in back yard!
  • 691 Answers
See if John Deere has a similar product. Ryobi & John Deere were together a while back and they carry more parts than the private label brand for identical items. If not your out of luck because it was probably mass produced in China for a limited time.
Posted on Sep 13, 2015
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
steve_lima
  • 181 Answers
SOURCE: I want to replace the drive sprocket on my Jonsered 451E chainsaw. I found a replacement sprocket, but don't have a manual to guide me through the process of removal. How do I keep the driveshaft from
the threads are left hand.i my self use a small butterfly air rachet to remove the nut. it spins fast enough to remove the nut.
Posted on May 12, 2009
  • 132 Answers
SOURCE: I have a Ryobi chainsaw Model 10532. I just need
Call or go online to the Homelite Repair Center. They are very helpful. Homelite makes the Ryobi Chain saws.
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: Where can i purchase sprocket for mastercraft
the new company is Troy-bilt but i found the part in a Mcculloch dealer
part # MC-6228-120104P
Posted on Jun 29, 2009
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
Sprocket removal on ryobi cs4046 chainsaw
takes a special tool and is left handed threads
Oct 20, 2012 | Ryobi Garden
I am looking for a Ryobi chainsaw 356mm manual. Model CS214
Contact Ryobi via their website and they will send you the PDF - http://ryobi.com.au/
Oct 06, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
My Ryobi 40cc chainsaw saw runs strong, but the chain binds and will not turn. The safety break is not engaged and the chain is not tighten to tight. I think it maybe the sprocket but it does not look...
If your chain has recently jumped off the bar while running, your chain may have "burs" on the drive links (part of the chain that rides in the bar groove). These burs will make the chain rub the inside of the rails and thus bind the chain in the groove. You can file these off with a flat file if there aren't very many, but you may need to just replace the chain. You can find files, bars, chains & sprockets for your saw at PartsBuggy.com.
Jan 18, 2011 | Ryobi Factory Reconditioned 18" 40cc...
Have The split cylinders in the Ryobi RY10532 40cc chainsaws caused grinding problems?
check chain sprocket take a rag over chain and pull it around should be smooth rolling also check nose of bar there are rollers check them out lota sawdust can build up behind clutch/sprocket
Apr 08, 2010 | Ryobi Factory Reconditioned 18" 40cc...
How do I adjust the automatic oiler for more oil to the bar and chain on a Homelite 360?
I'm not certain you can. Is there any mention in your Operator's Manual? It appears from the IPL early model 360s have an adjustment. Later models may not. I see no adjuster listed for the newer block of saws.
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches. HTH
Lou
Oct 11, 2009 | Homelite Garden
My ryobi chainsaw rcs 2040 keeps stopping but motor is still running, chain not moving!
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Sep 21, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a Ryobi chainsaw Model 10532. I just need to replace the piston & rings in it. Where can I get spare parts?
Jun 23, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Chain does n't rotate
Is the chain brake "on"?, can you pull the chain around the bar?
Is the drive sprocket teeth worn all the way through.
Does the engine high rev or is it loaded when you throtle up?
Jan 31, 2009 | Ryobi Garden
Garden Logo
132 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
