Question about Fellowes Powershred 480 Shredder
HOW DO I MAKE A FELLOWES C-480C SHREDDER PUMP OIL
  • 610 Answers
Hi Wendy, push and hold down the "bulldog" button and then hold down the "forward" button. You should hear the pump pumping oil. May take15 seconds before you hear a hum. If you do not hear anything, the pump may have to be replaced. Clogged oil nozzles or tubes could also cause a problem. This is a common problem and Fellowes re-engineered several components to fix this problem. You can google Fellowes to get a phone # to find an authorized service center. good luck.
Posted on Nov 25, 2014
Fellowes c-480c squealing noise
Shredders get incredibly dirty with paper dust. There is also a lubricant that you are supposed to put on the blades. There is a basic guide here:
Mar 13, 2015 | Fellowes Manufacturing Powershred C-480C...
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
What kind of oil should I use on my fellowes dm8c cross cut shredder
Staples Shredder Oil or GBC Shredder Oil usually about $12.00
Jan 15, 2013 | Fellowes DM8C Cross-Cut Shredder
Where to oil a Fellowes Powershred 320 CC paper
I continued to search via Google until I found the manual for this shredder, which I then printed out and read how to lubricate the shredder.
Jan 26, 2010 | Fellowes Office Equipment & Supplies
How to oil a fellowes os 8cs shredder
Oil straight down into the feed slot. 3-in-1 oil or Marvel Oil are OK to use.
Jan 05, 2010 | Fellowes Office Equipment & Supplies
Full bin light is always on!
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Jun 04, 2009 | Fellowes Manufacturing Powershred C-480C...
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
Fellowes Powershred 480 Shredder Logo
166 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
