Question about Ricoh Office Equipment & Supplies
There are lines appears in the paper if i took the photo from feeder ricoh 2045
What can i do ?
    Champion:
  • Ricoh Expert
  • 208 Answers
Does this happen when copying off of the glass? No? Clean the slit glass on the left. Still does it? Turn off the copier, remove the slit glass and the original glass. Gently slide the mirror carriage to the right. Carefully wipe the mirrors with a microfiber cloth and with a can air blow around the exposure lamp area. Reassemble and test. The most common problem is gunk on that slit glass which is easily remedied using a microfiber cloth.
Posted on Nov 23, 2014
SOURCE: Black line on copy while using paper feeder
try cleaning the feeder glass
Posted on Dec 04, 2007
SOURCE: Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Posted on Jun 05, 2008
SOURCE: HP PSC 2355 won't feed photo paper
Actually, I have used photo paper in this printer. It cannot be any thicker than 8.5 or 9 mil. Also, be sure you switch the Printer Preferences to Premium Photo Paper before printing. It's slow, but the photos print nicely.
Good Luck
Posted on Aug 01, 2008
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
Cogz
  • 1326 Answers
SOURCE: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Posted on Mar 15, 2009
Ricoh 240w cannot set paper tray error is not resolve any idea quick response required thanks.
SP 1960 Optional Paper Setting Enables installed options: Roll feeder (1 or 2 rolls),
paper cassette. This setting is not necessary if no
paper feed options are installed. (The default setting
is for the manual feed table.)
OR
BAD PAPER SET SENSOR
The paper set sensor detects the leading edge of the sheet. This switches on the drum motor, main motor, and registration clutch.
OR
Mar 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio 2045 paper jamming c section
check there is a small paper or there is dust at the laser unit so try take out the laser unit and clean it nicely
May 17, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio 2045, FAX delivery Report
Try pressing the USER TOOLS button and look for a reports menu.
Jan 21, 2010 | Office Equipment & Supplies
Vertical line is appear when make scanning from document feeder .. thanks
The glass the document is dragged across has an ink mark or liquid paper mark on it.
Clean thin document glass under the feeder.
Apr 27, 2009 | Ricoh IS420 Flatbed Scanner
Ricoh 2045 sc 990 when i fix printer its appear
Mar 14, 2009 | Ricoh Aficio 450 Copier
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
49 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
