Question about Bosch Tassimo TAS4511UC Coffee Maker
Green light at top will not come on and operation when pushed. I must hold button down and green light on the right side comes on. Then at the end of cycle I can release button and it finishes opera
Right side green light goes off and amber comes on after completion, But the fact is that I must hold down button manually to brew a cup of coffee. Thnk you.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Try cleaning the eye (code reader)
good luck
Posted on Nov 21, 2014
Testimonial: "Thank you! That was the problem. I gave the eye(code reader) a clean and it works like a charm!"
guru_fixya
  • 944 Answers
SOURCE: When I insert a tassimo
The yellow light appears when the water level is low.The water will be send through the valve.Please clean the valve and the Use distilled water not the soft water.The flow of water is blocked please clean it.Yellow will take the machine to stand by mode
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 22, 2010
  • 11800 Answers
SOURCE: Bosch Benvenuto built in Coffee
The quality of the coffee depends on the amount of actual coffee used - if it's too weak then not enough coffee is delivered to the filter by the dispenser. You will have to take the dispenser apart to see what's preventing it from doing its job - most likely it's clogged and in need of a serious cleaning.
Posted on Apr 03, 2011
SOURCE: water was running into tray
Hi, well usually a symptom such as this indicates a blocked/stuck/malfunctioning outlet valve? However without actually examining the unit, it is hard to actually tell? It needs to be looked at to tell exactly whats wrong, as this also may just be the "tip of the iceberg" so to speak, and there may be a bigger underling problem?
below is a link to obtain a copy of the service manual, should you wish to DIY.
http://www.helpowl.com/q/Bosch/TCA6301UC/Technical-Support/service-manual-benvenuto-b30/9032
Should you not wish to DIY, and really it isn't advisable unless you have skills in this area and more importantly spare parts, then what you need to do to get the least expensive and quickest job, will be to contact a Bosch local or head office, now ask here for a referral to an authorised service center, now when in contact here, ask for a service call or take the unit to them, BUT only ask for a "Quote" initially, this way you can get an idea of what you are up for cost wise, and then one can make an informed decision as to what to do, repair or replace.
Posted on Jun 20, 2011
SOURCE: Hello - I have a Bosch Tassimo that has worked
Mine does this all the time. There are several reasons why this happens . If you look at the machine from the front, find the part that pierces the disk at the top and dispenses the coffee at the bottom. This snaps in and out for cleaning. Push up on it until it pops out. If you have just used one of the hot chocolate discs and did not run the cleaning disc or rinse this part afterward, the chocolate clogs the spout and you will have to clean it out. If it is not due to a hot chocolate disk, I usually find that the small piece of aluminum that is punched out at the top has either gotten stuck inside the dispenser spout (sometimes more than one is in there) or is laying partially over the mouth in the center. The spout must be clean/clear before the green light will come on. After you pop it out, spray it out or push a pipe cleaner or other sharp object through it to clear it (skewers work, but I have to move it around to get anything that is stuck to the sides). After it's clean/clear, snap it back in place (make sure that it snaps into place). If that does not work, wipe the top and bottom of the disc shelf (there are sensors there, too). If you have had your machine for a long time (like I have), and none of that works, you may have to jiggle the top piece that covers the disc to wake the sense up. Good luck!
Posted on Jul 29, 2012
feet57
  • 5 Answers
SOURCE: when i put new pod in the plus service comes on
I had a similar problem , no amount of flushing descaling worked , had to buy a new one.
Posted on Oct 02, 2012
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
The orange light on the start button comes on and nothing happens
prepare machine for use first.
half-fill water tank, switch on unit and insert yellow TDisk (service disc) barcode down. Close the locking unit securely loud click, press green light repeat these steps 3 times. After that you will have the stand by orange/amber. Remove the Service Disc and store in the recess behind the water tank, Insert a Coffee Disc, close the brewing unit with click and green light should be on. press and it should work.If not go to shop where pruchased. Warranty.
Dec 29, 2012 | Braun Tassimo Espresso Machine/Coffee...
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
How do you turn on a Keurig to get a cup of coffee - I hit the button and it says green and ready but nothing is coming out - I put the cup's worth of water in the side container - what do I do to get it...
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
Sep 12, 2009 | Keurig B50 Coffee Maker
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Bosch Tassimo TAS4511UC Coffee Maker Logo
518 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
