Question about Fuji Newest 2.0 27 Speed Shimano Road Bikes Bicycles
Grease rear bearings in my road bike.
I need the proper sequence putting the parts back on the rear axel.
    Master:
  • 388 Answers
Try this:
Posted on Dec 03, 2014
How do you change the rear tire on a 2008 Street Glide? gotta get it off the bike.........
1) Remove hard bags.
2) Use a marker to mark a position of the belt tension cams on the axel. This will help you put the proper amount of tension on the drive belt when you put it all back together. The left cam is welded to the left side of the axel. The cams are used to tighten or loosen the belt tension. You will see what I'm talking about when you get there and look at it.
3) Remove the two bolts from the rear of the left side bag support. Then loosen the front bolt of the bag support. (Remove the left fusebox cover to access the front support bolt.) Lower the bag support. This is necessary to slide the rear axel out.
4) Remove the two banjo bolts from the rear brake bracket and slide off from the rotor. Support brake with something so you don't damage the brake line.
5) Look carefully at the spacers on the axel and note, along with the order.
6) Loosen the cone nut of the axel on the right side of the bike, but don't remove.
7) Use a bike jack to raise the bike so that the rear wheel is barely touching the ground. Just enough that you can turn the rear wheel and feel the treads rubbing the ground.
8) Remove the cone nut from the right side, along with the right alignment cam washer
9) Genlty tap the end of the axel from the right side of the bike until it slides out from the wheel hub.
10) Pull the axel from the left side, take note of IDS washer and spacer order and position.
11) Slowly jack up the bike until you can pull off the belt pulley...that also contains the IDS (Isolated Drive Sprocket) NOTE; Check that damned IDS bearing in the drive pulley. I have gone through 4 of those crappy bearings...usually every 10k. If the seal is broken on the IDS bearing, get it replaced. This is the wicked gremlin of the 08 FLHX. The rear IDS pulley should just pull away from the hub at this point.
12) Jack the bike up until you can roll the tire, or get it out from underneath the bike. Did I tell you to strap the bike so it doesn't fall over? Just in case ya'know.
It all goes on in the reverse order. I never mount the tire on the rim...I have someone else to that and the balancing. Make sure none of the rubber isolators in the drive pulley have fallen out. Once you have the axel back in, tighten the cone nut enough so that you can tighten the drive belt by turning the cams from the left side of the axel. Use the paint marks you put on the right side of the axel cam to get the drive belt tension where it was at the time you started this whole process. Tighten hand tight, then loosen one full turn, then tighten the cone nut on the right side to torque specs. (Damn, I can't remember what that was. I think 90 - 110 foot pounds but I can't say that with certainty. I think the brake bolts are 35 to 45 foot pounds.)
Hope the helps. You can get cheap PDF shop manuals online if you look hard enough. The best investment I have made was a Harley Shop Manual for the bike...but they ain't cheap.
Feb 21, 2011 | 2008 Harley Davidson FLHX Street Glide
Rear axle was taken out of cruiser bike .have new axle how does it all go back together cones bearings pads nuts a diagram would be nice
Diagrams for hubs are specific to the brand and model. There are several book resources that explain in general how a hub system goes together, just about any bicycle repair manual you can find.
If your cruiser bike has a coaster brake it will increase the complexity.
There are a number of specific tools you need to do the job correctly including wrenches and cone wrenches as well as new lithium grease for the bearings. If you do not already own the proper tools this may be a case where it is simpler and cheaper to take the parts into your local bike shop and have them put it back to together, since it is already in pieces the cost should be minimal to reassemble assuming all your parts are good. Cones are not pitted, etc.
Dec 08, 2010 | Huffy Cycling
Rear axel and bearings. we need to know how to put the rear end back together.
You didn't say which year or model Yamaha you have. It makes a difference. Tell you what, go to the website below and you can see a parts diagram for your bike. That should answer your question very well. Please rate my answer. Thanks.
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
Aug 19, 2010 | Yamaha YZ 250 Motorcycles
Bad rear axle bearing and seal on a 2000 jeep grand
the bearing does not always have to be really bad for the seal to fail. Centrifugal force will throw axle grease outward where it gets on the rotor. That can make it feel like the rotor is out of round. If grease got on the brake pads I'd replace them and perhaps even the rotor. As far as the caliper being frozen, possible....check it out when you have it apart. You can have more than one shoe untied at the same time. Not always, but it can happen.
When replacing the seal make sure you put some grease on the lip before putting the axle back in. by doing that it won't fail from dry running before the diff lube reaches it.
May 15, 2010 | 2000 Jeep Grand Cherokee
Do you have to remove the axels to change the brake shoes on a 94 chev 1 ton?
Yes, the axles have to come out, then the wheel bearings, and finally the drums will come off. Be careful when pulling the drums, pull them straight off the housing, do not allow them to drop on the housing tube, doing so will damage the inner wheel seal. When reassembling the bearings back in the drums just wipe grease on the outside of the bearing, do not pack them with grease. After the drum is back on put a squirt of rear end dope in the hub before putting the axle back in, top up the level in the rear differential, this is where the rear bearings get their lube from.
Apr 06, 2010 | 1994 Chevrolet C3500
Replacing bearings in the rear axel- 99 boss hoss- replaced rearaxel with newer housing with grease zert- is ther a sealed bearing for this!
Hi, Davef927 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Replacing bearings in the rear axel 99 boss hoss replaced rearaxel with...
http://www.autopartswarehouse.com/partsearch/axle_repair_bearing.html?005=45659879650&007=Search&gclid=CPSI_MCh-8kCFckYHwodmmICbw
http://antakesuma.xyz/fds/b/boss-hoss-bhc-3-ls2-2008-custom-cruiser-v8-automatic-repair-manual.pdf
https://www.bosshoss.com/parts.asp
Boss Hoss Cycles Contact Us
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 10, 2009 | Boss Hoss BHC-3 ZZ4 Motorcycles
Can't fit my rear axel
hi jenny,
what is the brand and model of your frame and your rear wheel assembly?usual fitting is better made with the bike mounted upside down, letting gravity make the balancing. but this is possible to most mountain bike, not most road bikes.
looking forward to your reply.
regards,
voodoo
Apr 19, 2009 | Cycling
Play in rear wheel
bearing end play is .002''-.006'' this is done by inner spacer shims. sealed bearings can be installed instead of timkin and they are practicaly maintenance free
Apr 06, 2009 | Harley Davidson FXSTS Springer Softail...
Fuji Newest 2.0 27 Speed Shimano Road Bikes Bicycles Logo
328 people viewed this question
Top Fuji Cycling Experts
sharky633
sharky633
dante
Donald Ayers-Marsh
Are you a Fuji Cycling Expert? Answer questions, earn points and help others
