Question about Technics Audio Players & Recorders
What are the functions of the impedance button on the Technics SA-AX730
    Sergeant:
  • 244 Answers
This allows you to select the correct amplifier output impedance for the particular speakers you have connected, Proper selection insures the best efficiency, response and prevents potential damage to speakers or the amplifier, Refer to page 17 of this manual:
http://audio.manualsonline.com/manuals/mfg/technics/technics_sa_saax730.html
Posted on Nov 20, 2014
  • 20 Answers
SOURCE: Technics SA-AX730
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Even though fused, your receiver has internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
marsrover
  • 682 Answers
SOURCE: Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Posted on Aug 06, 2008
  • 22 Answers
SOURCE: technics sa-ax730 won't play a&b speakers at same time.
Low imp probably means "Low Impedance". You've got either too many speakers hooked up in parallel on the same binding posts or spring contacts or the single sets of speakers on A & B are low impedance to begin with (i.e. 4ohms).
When you switch between A, B, and A + B, the last setting just puts B in parallel anyway.
Too low an impedance means higher current and the receiver may not be capable of handling it. Check your owner's manual for recommended speaker impedances.
If you test with a single set of speakers, switching the actual cables from A to B should work (even at a nominal 4ohms). If that's the case then you will need a different set or sets or speakers to hook up to B. If it doesn't work at all and still says "low imp", test with a known higher impedance speaker (i.e. ~8ohms).
If none of that works, you're on your own.
Good luck in any case.
Posted on Feb 04, 2009
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
  • 4 Answers
SOURCE: technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Posted on Jul 23, 2010
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
I have a panasonic home theater system and am trying to hook it up tp my technics reciever and its not working how do i do it
EVERY TIME I TUEN ON MY RECEIVER IT STAYS IN THE STANBY LIGHT AND IT DNT ALLOW ME TO LISTEN TO MUSIC
Oct 03, 2013 | Technics SA-AX730 Receiver
Fan is not working?
are u sure the fan is not working because on my ax730 the fan will only come on if im booting over half volume
Jul 27, 2010 | Technics SA-AX730 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Technics sa-ax730 won't play a&b speakers at same time.
This is similar to protect mode in that the amp has detected a short in the output and has shutdown to prevent damage. Without seeing the unit, I'm a bit hesatant to suggest repair tips. At this point, I would suggest you get a detailed estimate from a local shop. We should be able to guide you through the actual repair once the results are posted here.
Dan
Feb 04, 2009 | Technics SA-AX730 Receiver
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
"OVERLOAD" message-Technics SA-AX730
You can't do it yourself only a good technician or repair center.I don't know the fix it cost.
Jul 07, 2008 | Technics SA-AX730 Receiver
Video Problem
You most likely have either bad connections from the jacks to the main PC board or the video switching chip has an internal problem. Try resoldering all of the input jacks first and update this with your results.
Dan
May 12, 2008 | Technics SA-AX730 Receiver
Your speakers are way tp powerful you should only use speakers just over what the amp is rated at the most and check your impedance is not lower then 6 ohms and turn the bass to half way i am using 60 watt bookcase psb speakers and they work just fine and they pound no problem
Aug 24, 2007 | Technics SA-AX730 Receiver
Technics SA-AX730
Jul 07, 2007 | Technics SA-AX540 Receiver
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
