Question about Maytag Matag 25.6 Cu Ft Side By Side Refrigerator, MSD2655HE
I changed the water filter on my Matag msd2454grq with the exact same filter. The water was working for a few times, but after a couple minutes no water or ice will come out?
MSD2454GRQ
    Scholar:
  • 159 Answers
Did you check your water valve under your sink.could have been a minor mistake of turning the Handel the wrong way.
Posted on Nov 20, 2014
I changed the filter and now no water or ice will come out.
The replacement filter may have been installed backwards.
Nov 20, 2014 | Refrigerators
I just changed the filter and flushed the water for a few minutes, however, it's still dripping
Was it leaking before changing the filter? It could be that the water valve in back is leaking a bit. Sometimes the valve gets a very small bit of grit in it and doesn't completely shut off. The way to tell is to remove the hose from the valve and see if water is dripping from it at the valve. If it isn't then maybe the water reservoir is partially frozen and causing a pressure build up in the reservoir. If this is the case the dripping should stop after a couple minutes. I would look at the valve.
Sep 12, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Msd2454grq in need of diagram for plumbing water/icemaker system
ok here's how it goes, first line from water goes to the filter then out of it to the solenoid vale, then it goes to either the icemaker or inside of the refrigerator to the resevour tank and the to the door.
Dec 20, 2008 | Maytag MSD2454G Side by Side Refrigerator
GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Dec 29, 2007 | GE WCVH6260F Front Load Washer
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Refrigerators Logo
52 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
