My beats mixr snaped on the right side and I need help fixing it.
  • 3,368 Answers
Before somebody can help you you need to give us the make and model number. You have the unit and know what it is, we don't.
Posted on Nov 27, 2014
How can I repair my Beats Mixr headphone in which one of the ear is not working ?
Presumably this is a wiring problem, for one of two reasons. If you look at the RCA plug that you use to hook into your stereo, you will see two black bands on it - one band for each signal - left or right. If there isn't a good connection, often you won't get sound in both earpieces. First try inserting the plug into your equipment part way, or rotating it carefully, to see if you can get both ears working. If that doesn't work, then the problem is either the wire for whatever ear is not working, not being connected properly at the RCA plug itself, or at the ear in question. You can unscrew the plastic cover on the RCA plug to see the wiring connection. But if the connection is bad at the actual earpiece, I would suggest returning the headphones, rather than taking them apart. Good luck.
May 23, 2014 | Beats By Dr Dre MIXR Black Over-Ear...
My loose beats mixr
You can take the screws out then you can put a rubber that you use fir plumbing tap or you can find a same color washer that you can use between then screw back on will do the job . You can get them from Home Depot of lowes of local shop 12_27_2013_11_24_39_pm.png
May 10, 2013 | Audio Players & Recorders
The driver side bottom ball joint snaped how do u fixs it
it needs to be replaced take it to a mechanic unless you have the knowlage and the tools to repair
Sep 27, 2010 | 1994 Ford Crown Victoria
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
May 11, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Think my sim card as snaped in side can you
Yes remove the battery cover.You will see a battery and a sim .You often need to remove the battery before getting at the sim.
Check if sim is damaged.If it is phone your supplier e.g orange,tmobile for a free replacement.
Hope it helped.
Dec 09, 2009 | Cell Phones
Sensor
There are spring tabs on the inboard side(engine side) of the reservior that are part of the sensor and you have to squeeze together in order to slide the sensor out. The springs run up and down as compared to the master cylinder. Good Luck
Aug 24, 2008 | 1999 Chevrolet Malibu
331 people viewed this question
 Grubhead
Grubhead
