Question about Samsung Televison & Video
How can you tell which Fan is "# 1" on Samsung Model # HL-T6187S ?
When I took the Back off, I see only see 2 fans. Is there another one that I am overlooking?
    Master:
  • Samsung Master
  • 687 Answers
You have 1 large one by the lamp, 1 by the DMD pcb to cool the DMD chip , & 1 by the LED ICs(you need to pull the light engine back a bit to see this one)
see this website for various pix: https://images.search.yahoo.com/yhs/search;_ylt=AwrTcd4GMc1UeIQARtAnnIlQ;_ylu=X3oDMTB0MzkwOG5yBHNlYwNzYwRjb2xvA2dxMQR2dGlkA1lIUzAwNF8x?_adv_prop=image&fr=yhs-mozilla-001&va=samsung+light+engine+BP96-01729F&hspart=mozilla&hsimp=yhs-001
Posted on Jan 31, 2015
3 Suggested Answers
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
Slinteriors
  • 8617 Answers
SOURCE: hl-t6187s looking for fan #1
you can get replacement fans from www.tvrepairworld.com and also free tech assistance for proper diagnosis
Posted on Mar 16, 2012
Do you have a picture that Identifies the parts on the backside of Samsung TV Model # HL-T6187S ?
you have 1 large one by the lamp, 1 by the DMD pcb to cool the DMD chip , & 1 by the LED ICs(you need to pull the light engine back a bit to see this one)
Nov 20, 2014 | Samsung Televison & Video
HL-t6187s control problems
Check with Samsung, your model falls under a class action settlement related to power supply issues that your TV may be experiencing. Here is a link to more information about this settlement.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Jul 16, 2012 | Samsung HL-T6187S Television
Hl-t6187s looking for fan #1
Mar 16, 2012 | Samsung HLT6187SAX 61" DLP HDTV
hello Harley,
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
My tv is saying check fan no.1 and hen goes off
On the Samsung HLT6187S models (there's no difference between S, SX, SAX, etc) Fan #1 and Fan #3 are in different locations but the same part. Fan one is the fan that you see when you take the back off the set. It's right there on the left sitting at a diagonal. It draws air from the lens to keep it cool.
Fan #2 is the large fan that pushes air to the right of the TV (as you're looking at it from the back).
Fan #3 is the LED PCB fan, all the way around the right side of the TV back.
All three fans are simple to replace and takes about 3 minutes to do. Conventional wisdom stipulates replacing all three while youve got it open.
Oct 15, 2010 | Samsung HL-T6187S Television
I have a Samsung DLP Model HL P5063W which has gotten increasingly loud, due to the cooling fan located directly behind the projection light. I took the light and the fuse panel away from the fan cleaned...
hi there.not sure on the shroud removal bit,but a good oiling of the fan bearings should fix the noise issue.its a common grumble with computers and suchlike.avoid wd40,it only lasts so long.engine oil is as good as any to use! hope the info is of some use! regards, steve
Oct 05, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
How to replace replace fan no.2 on Samsung HL-S4266w? how to re
tack out engine take out lamp take of lamp housing assembly replace fan
Apr 20, 2010 | Samsung HL-S4266W 42" HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
