Question about Ovens
Are the main bottom oven doors on the stoves gl716 and the gl916 the same size
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Posted on Jan 07, 2009
  • 250 Answers
SOURCE: Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Posted on Nov 16, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
barkencoa
  • 3463 Answers
SOURCE: stoves main oven door stays slightly open
You need to replace the oven door hinges as the springs are probably weak.
Posted on Nov 28, 2010
SOURCE: HOW DO I GET THE
how do i change grill element in top oven
Posted on Nov 20, 2012
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Whirlpool wall oven door handle fell off how to reattach?
I just unplugged the main switch then cleaned behind the oven and re-plugged it. It fixed my problem. It is very basic but it works.
Aug 23, 2012 | Stoves Ovens
Morison,
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
Nov 15, 2009 | Stoves 720EF Electric Double Oven
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Hope this helps
Oct 28, 2007 | Ovens
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
