Question about Proscan Televison & Video
I replaced the power supply unit on my 50" ProScan flat screen and now it wont even turn on just a clicking sound when you hit the power button.
My tv made loud pop and smelled like it was burning and I lost the picture. After speaking with Proscan they said it was the Power Supply unit. Bought new and installed and now it will not turn on and just makes a faint clicking noise.
    Top Expert:
  • Proscan Master
  • 34,743 Answers
The replacement power supply could have been installed incorrectly or may have been defective as received.
Posted on Nov 20, 2014
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 62 Answers
SOURCE: power supply
Call 800-726-4405 - But the part may not be available - request an exchange through the manufacturer. By law the manufacturer must provide parts for 5 years.
Posted on Mar 29, 2008
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
SOURCE: Tv makes clicking noise but won't turn on
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
Posted on May 06, 2009
50 in proscan led tv powers on then has black screen but can see screen work with flashlight
Your backlighting is no longer working.
With a LED TV it's an array of LED's that light it, in an LCD TV it's fluorescent bulbs that do the backlighting.
There's a chance it's the power supply board that's bad, unfortunately, it could also be the backlighting itself.
You'll need an expert to look at it to make that determination.
If you don't know Electronics, don't open it up yourself! There are hazardous voltages even in flat screen TVs. The hazardous voltages are there even when the unit is unplugged!
Jul 17, 2016 | Proscan Televison & Video
My proscan 32lc30s57 not turn on
Purchase 32 inc Proscan on black friday, 7 months later, tv would not turn on, the light comes on, but screen is all black, what should I do
Feb 27, 2013 | Proscan 32LA30Q Television
Proscan 42LA45H has picture and no sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Proscan 42LA45H 42 in. LCD TV
26la30q wont turn on
Hi
You have to start checkin from its main ON/OFF switch itself. If the switch have any contact contact trouble, the set will not turn On, even though you hear the click sound from the switch. If switch is Ok, then you have to come to the power supply regulator board. It can be easly recogonized the powe supply regulator boad. The main supply line will go straight to it. There will be more that 5 or mor secondary voltages from it, according to Tv model. These secondary wupplies will energzed only after the power supply switching circuit work properly.
Ther is a fuse [ a cartridge type; replaceable]. Check the fuse first. If it has blown; be carefull when you replace it; because there must be some reason for the blowing of that fuse. It is really a protection device. Before replacing it, you have to check the entire power supply board for some short circuit. If you have sound knoledge in repairing Switched Mode Power Supply [SMPS]; just proceed. Otherwise get it repaired by any experienced service technican or by authorised service center for Proscan. OK.
Jul 08, 2011 | Proscan 26LA30Q 26 in. LCD Television
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
I have a sharp-aquos flat screen tv model#LC-37GB5U and my problem is it turns itself off and then wont come back on.yesterday it worked perfectly,today it wont even turn on.when i push the power button...
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
Jan 20, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
109 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
