Question about Kenmore Sewing Machines
Clutch of Kenmore 1311 zig zag sewing machine won't disengage-how can I resolve?
Taking the small screw out. Taking off the top cover of machine and looking at wheel from that vantage. Loosening the screw. It is locked on the wheel and will NOT disengage by hand
  • JC howes
    JC howes Nov 21, 2014
    The problem is with the small screw out of the clutch-the clutch still will not budge to remove it
  • JC howes
    JC howes Nov 25, 2014
    Not yet. Problem is how do I oil that part if I can't get the clutch to budge? Can I take the clutch screw out and instill oil in the hole?
  • 86 Answers
Have you oiled it? Often can get even *very* old machines to loosen up with a good oiling and cleaning.
Posted on Nov 25, 2014
  • JC howes
    Not yet. Problem is how do I oil that part if the clutch won't move to remove it? Can I take out the clutch screw and put oil in the hole?
3 Suggested Answers
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
Kenmore 385.12490
Check the position of the Button Hole Stitch adjuster that is directly under the stitch length control. It looks like a flat head screw and should be straight up and down for normal sewing.
Jun 30, 2013 | Sewing Machines
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Jan 20, 2010 | Sewing Machines
Can't tighten clutch on Kenmore zig zag sewing machine.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Feb 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
65 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
