Question about Dryers
My Frigidaire affinity dryer model AEQ6000ES2 will not start there are no error messages it just will not start. Please help.
  • Dryers Master
  • 3,287 Answers
You didn't mention if you knew for sure if there was power to the dryer or not. If a gas type, it should have a standard 120 volt outlet that you can plug a lamp, radio, etc. to see if power is present. If an electric type, it will have a 240 volt outlet specifically for a dryer. You will not be able to test the outlet unless you have a meter, test light etc.
Locate the electrical panel in the home or building for your space. If you have a gas dryer, look for single pole 15 or 20 circuit breaker that is off or tripped. If an electric dryer, look for a double pole (double-wide) 30 amp circuit breaker that is off or tripped. regardless if a single pole or double pole, if found off, push the handle back to on. If tripped, push the handle to off, then to on. Check the dryer to see if it runs.
Lastly, some of the newer appliances have mini-computers or processors in them. Like you home computer - it may encounter an issue and gets stuck. You should locate the circuit breaker for the appliance in the electric panel and shut it off for 30 - 60 seconds. Then turn back on. This is similar to a "reboot" and may get the dryer working again for you.
Posted on Nov 20, 2014
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
Aug 13, 2014 | Frigidaire AEQ6000ES Electric Dryer
The belt is broken i have a new one i need to know how to get inside the dryer
Hi Cyndy s
Go to the following webpage and watch the video on how to dissassemble your Fridgidaire Affinity Dryer this is for the front slide replacement but you will remove the drum and you will see where the belt goes.
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
For parts and a schematic of your dryer.
http://www.appliancepartspros.com/parts-for-frigidaire-aeq6000es2.html
If the belt is broken and you don't know how to route the belt check out the following picture
Please rate me
Bud
Oct 25, 2012 | Frigidaire Dryers
MI SECADORA ES FRIGIDAIRE AFFINITY MODELO AEQ6000ES2 Y ME DA ERROR E68
confirma que sea realmente el error del boton atorado y si todo esta bien agrega un resistor de pull down al micro eso me funciono en una secadora que arregle
Apr 24, 2012 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire Affinity dryer (mod# AEQ6000ES2) turns on but drum will only turn for a few seconds then stop. What could be the problem and can I fix this myself?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 24, 2011 | Frigidaire AEQ6000ES Electric Dryer
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
