Question about Garden
Put my tractor in freewheeling
I can't seem to get my tractor to go into freewheeling. The rod is free and moves in and out as well as rotates. It is not a good picture in my manual so is no help. Does it freewheel when the pin is in or out? The tractor works find otherwise.
    Sergeant:
  • 253 Answers
You don't say what kind of tractor, model, year ???
Posted on Nov 20, 2014
Why will my differential not lock back in
roll your tires back and forth while shoveving in rod
Aug 26, 2014 | Garden
Troubleshooting
pull out the wire or rod on the back of the mower. that will let it freewheel
Jul 26, 2014 | Cub Cadet Garden
Loss of tension for a kettle coach rowing machine
The fly wheel has a 'freewheel' mechanism similar to the rear wheel on a bicycle. It needs cleaning and regreasing with light grease to free it up and make it work properly. The job is not difficult but needs some diy knowledge. Before trying to remove the fly wheel some slack will need to be created on the 'bungee' return cord and anchored securely. You will also require circlip pliers to remove the shaft. The freewheel mechanism is a set of needle bearings that move forward in their recess to allow the wheel to rotate and move back and lock when the wheel rotates in the opposite direction. These need to be free moving and old grease thickens and becomes sticky. Clean with something like GT 85 and regrease with a light grease.
Dec 29, 2013 | Kettler Coach Rowing Machine
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to place freewheel control into engaged position
there is a rod that hangs out above the hitch you pull it out and move it into a released position when done release and push it in
Jul 01, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Rear end will not free wheel and reverse not moving very fast.
you did not say what kind of mower but mine has a rod sticking out of the back that you pull out to allow it to freewheel
Jan 24, 2018 | Craftsman Garden
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Apr 28, 2009 | Garden
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
