Question about ahappydeal CUBOT M6589S Android 4.2 3G Smart Phone with 4.7 inch HD720 Screen Quad Core 1GB RAM Dual Cameras GPS White
How to answer cubot p9 smartphone
Swiping the locked screen just hangs up
How do I remove swiping on my phone
To disable the Screen swipe lock screen simply go to the settings menu of yourphone, then choose My device. Now from there, look for the Lock screen option and tap it.
Remove Swipe Screen To Unlock Galaxy S4 Marshmallow vs Lollipop ...
visihow.com/Remove_Swipe_Screen_To_Unlock_Galaxy_S4.......or see if this link helps you out. How do remove swiping on my phone Google Search
Oct 15, 2017 | Cell Phones
How can you bypass swipe and go directly to your apps when turning turning it on? Thanks
Hi Mark.
Depending on cell phone model yours may be a bit different.
As a guide, I'll outline my phone's procedure.
The 'swipe' means that your security screen-lock is active.
'Settings', 'Security', 'Lock Screen', 'No'.
Confirm if asked.
Reboot/restart phone.
Oct 13, 2017 | Cell Phones
Link it to wi fi
You might want to follow this video on how to get into some of the menus
https://www.youtube.com/watch?v=QprDsysEAqw
Feb 28, 2016 | CUBOT P9 5 QHD Screen Unlocked Smartphone...
Galaxy 6. How can I bypass password?
Samsung Galaxy S6: How to bypass Password:
Hello. You'll need to enter in your password first in order to get into the phone, and then set the phone to no security so that you can get into your device without having to enter it all the time, if it has become annoying. I would suggest at least using a simple swipe pattern to lock your phone
1. Enter screen unlock password
2. Go to:
Settings>Device>Lock screen>
(under screen security)
tap on "Screen Lock"
(enter your screen unlock password to confirm)
select: None, or Swipe, or pattern
if you are unable to select: None or Swipe
because they are greyed out
like this:
bypass-password-galaxy-6-kyzl0pi20tqzz121bvlihxv0-2-0.jpg then you will have to just clear the credentials in security..
(this happens when you select a high security option)
go to:
Settings>Security>Clear Credentials
then go back to
selecting your new lock screen option
then, Go to:
(enter your last screen unlock password to confirm)
Feb 12, 2016 | Samsung Galaxy Cell Phones
I setup a password to lock my phone I want to set it back to just swiping screen
go to settings (under device) go to lock screen go to screen lock type your password and you should get the option to select swipe.
Feb 05, 2016 | Samsung Galaxy Cell Phones
How do you remove apps from cubot p9
Try this way: Settings- apps- choose app you want Uninstal- touch 'Uninstall'
If you want just remove from screen, do this- touch apps, hold 1~2 sec. and move to the red x on top (usually on top)
Feb 04, 2016 | CUBOT P9 5.0& Capacitive Touch Screen...
My phone swipe the screen to open,now I swipe screen lock can't open
All you need is open your phone and locate the touch screen connection that connected on your screen, then remove it carefully and clean it and insert again, then open your phone,,,
if nothing's happen, you will now have to buy a new screen to replace it
Aug 19, 2015 | Samsung Galaxy Cell Phones
Last Gmail I looked at is locked on screen on right side.
Close GMail first by swiping it off the running apps screen.
Uninstall GMail using the *Uninstall* option in:
Settings > Apps > Downloaded > GMail. Touch GMail and you will get another screen with an option to uninstall it. Touch the uninstall button and it will uninstall.
Then go to the Google App Store and download it again. It sounds like the Mail app got corrupted somehow.
May 11, 2015 | Tablets & eReaders
When I turn my cubot phone on, it comes on , but thAts it, won't do anything, and hasn't been damaged at all. What do I do?
Try phone reset
Power off the phone, hold the volume down key and press down the power button simultaneously for about 15 seconds. The phone will power up and shows an exclamatory mark. Then release the button. Press the volume down key, it will display the menu. Choose the menu by press the volume down key. Choose "wipe data/factory reset", press power key to enter in, then choose "delete all user data", press power key to confirm. Wait until it indicates "data wipe complete". Then choose "wipe cache partition", confirm with power key. Wait for a few seconds, the screen will shows "cache wipe complete". And at the last, choose "reboot system now", confirm with power key, then the phone will reboot.
Mar 14, 2015 | CUBOT Cell Phones
What does it mean when there is a tiny circle with a padlock inside located by the batteryline at the top
That you have locked the screen orientation. Swipe up from the bottom and unlock it with the lock icon.
Mar 09, 2015 | Apple iPhone 5
ahappydeal CUBOT M6589S Android 4.2 3G Smart Phone with 4.7 inch HD720 Screen Quad Core 1GB RAM Dual Cameras GPS White Logo
47 people viewed this question
Top ahappydeal Cameras Experts
Are you an ahappydeal Camera Expert? Answer questions, earn points and help others
