Question about Kodak Vintage Carousel 650h Projector With Remote & Booklet & Original Box
I'm trying to see if I have power at the soccer where re bulb goes in. Know luck yet.
I've tried to see if I have power at the light source. No luck
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Powered but not booting. No visual. HDD light not doing anything.
    Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
    Let me know how it goes
    Cheers
    Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
    I have a 96 Cavalier and my passenger side low beam does not turn on (high beams OK) & my horn doesn't work either. I've replaced the bulb with no luck. Any suggestions?
    The light socket itself could be bad. If you turn on the lights and put a meter on it you can verify there is power at the socket. If not you still have to trouble shoot some more. No power at socket could be wiring that went bad or melted but you will have to remove the socket and test the wires themselves. No power at the wire bare ends you have to go back to the fuse distribution and check that. Low voltage sucks for this very reason. good luck.
    Nov 12, 2012 | 1996 Chevrolet Cavalier
    I have a f 250 superduty 7.3 1999 , the rear running lamps are not working but all others do. please help i 've checked fuses but didnt find any bad , also replaced bulbs just in case
    Had a similar problem with my 97 power stroke. somehow the plug in the wiring harness below the bed at the rear of the truck vibrated loose I had all lights but brake lights. Or it may be a ground wire issue. Good luck. Let us know how it works out.
    Nov 08, 2012 | Ford Cars & Trucks
    I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
    if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
    Nov 01, 2012 | Computers & Internet
    Sharp aquos won't turn on
    if it was a new tv you can ask the supplier for check up it was covered with warranty.
    Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
    Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
    Timer is probably wired incorrectly.
    Copy following links for correct wiring, and larger instructions.
    I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
    http://waterheatertimer.org/How-to-set-timers.html
    http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
    Jul 31, 2012 | Hardware & Accessories
    Problem concerns Samsung HL-S5087W. All of a sudden, TV goes through 3 startup cycles and shuts down resulting in 3 blinking lights on front panel. What I've done: Completely cleaned inside of...
    3 blinking led light at the front panel is an error code for lamp malfunction. If you've already replaced the bulb and yet the symptoms remain the same, then high chance that the fault came from the ballast board because the supply voltage is present.
    Confirm if the bulb will lit upon powering on the unit. Open the lamp cover, bypass the lamp cover switch by putting tape to make it in closed position (making it still the lamp cover is attached to the housing) and then power on the unit. Check if the bulb will ignite or will light up, if not, you have to replaced the ballast board.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    Jul 14, 2011 | Samsung HL-R5087W 50" HDTV-Ready...
    Kodak Vintage Carousel 650h Projector With Remote & Booklet & Original Box Logo
    219 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
