Question about Garden
21 hp kohler courage sv610-3213 has no spark. Replaced coil and still no spark.
  • 1,169 Answers
First install a known good spark plug and check.
If still not firing disconnect the coil kill wire and test.
If still not firing and the flywheel magnets are good and strong then you have another bad coil. In this case put a voltmeter between the kill wire and ground. Now slowly cycle the ignition switch if any voltage spikes shows up then you a bad ignition that it has fried another coil. If this is the case then you must replace the ignition switch before you install another or the same thing will happen again
These ignition coils are not designed to have anything other ground applied the kill terminal. Applying the battery voltage at anytime will kill it ie intentional application of 12V.
Posted on Nov 20, 2014
Testimonial: "Hey Eugene, i tried what you said to do with ignition switch and coil. I didn't get a voltage spike. the mower was running and then just shut down. was cutting the grass at the time. I did notice an odor from the battery. Have new battery in it. Did old battery fry something?"
  • 468 Answers
SOURCE: how to determine which safety switch may be faulty
Take the wires off the switch, and use a jumper wire between them(simulates the switch being closed.) Do this on one, if it doesn't work, move to the next one, etc until it spins over. If you want, you can even splice them together, or get some spade connectors and make permanent jumpers like most people do. Just don't do anything that the switches are supposed to protect against, like getting up off the seat and putting your fingers under the deck, or starting it in gear, or whatever.
Posted on Mar 21, 2010
Testimonial: "Thanks for your time Labrat. You were very helpful. "
RonInFla
  • 86 Answers
SOURCE: Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Posted on Apr 10, 2010
huffman49
  • 235 Answers
SOURCE: MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
  • 24 Answers
SOURCE: what is the gap between
It is not as critical as some think. A regular playing card works great. Place in between and tighten up the bolts, piece of cake as they say.
Posted on May 08, 2011
philwalker78
  • 608 Answers
SOURCE: How do you reset the change oil light on a kohler
Hi, the light will cancel automatically after another two hours use. Regards Phil.
Posted on May 11, 2011
I have a kohler courage 26 hp pro v twin its not firing on left side swap coils around and it fires on the right fine so both coils are good checked wiring and push rod they re fine any help please
Since you know the coils are good, there is only a few possibilities. The grounding wire must be causing a short to ground. Remove the ground wire from the coil. Check your spark plugs, are you swapping these too? The gap on the coil, this is a long shot, but if it is too far away, it will not fire. Are looking at the spark form the plugs? By firing you mean running, or spark. If you mean by running, check the compression. You may have a stuck valve, usually the exhaust.
Jul 14, 2015 | Garden
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Are there a difference in the coils on a 26 hp kohler?
Yes and the numbers should match up on both old coils. The new coils will have a different part number because they have updated them.
Jul 03, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
Stars missing out when it gets hot
put a spark tester on each cylinder you might have a coil going bad each cylinder has it's own
Aug 28, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Hydro pump reserve blowing out fluid on Toro z- master
is this all after the parts where changed and while bleeding out the air put the system under vacuum
May 13, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Wirer up a lawn mower coil
A coil is simple gap it from the flywheel about the thickness of a business card--attach the ground wire and plug the spark plug in.
Tada!
If yours looks more difficult send me a model of your engine and I will give more detail.
joe
Nov 01, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
