Question about JVC LT-42X788 42 in. LCD HDTV
I have sound no pic and t-con replaced. what do you suggest?
T-can board replaced
    Top Expert:
  • JVC Master
  • 75,311 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 21, 2014
Vizio vx37LHDTV Have back light No sound, no picture
Are you sure all the boards you received were good?
Mar 22, 2018 | Vizio Televison & Video
Samsung UN50H6350AF LED TV. No picture. I do get backlights and sound. (See pic) I tried replacing the main board and the T-con board and there was no change. Any suggestions? Try power supply board?
You have wasted enough money guessing bite the bullet and replace the TV. I have done this same thing and regret it to this day, should have just junked it.
Dec 02, 2016 | Samsung Televison & Video
Samsung 46" lcd tv changed t-con brd 5-mnths ago worked fine. started showing up/dwn pixel lines the went white. sound is great pic is white. what board would I chang now? mdl:ln46a530p1f
It sounds like your T-Con board went out again. You might re-seat your ribbon cables just in case you didn;t get them in good from the last repair. If that doesn't help I would say that your T-con board went out again.
May 05, 2016 | Samsung LN46A530 46 in. LCD HDTV
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
I have a LG 50LN5600 LED Smart TV w/sound no/pic Have replaced the power supply board and t-con board. Main board only one left and research says that this would not be a main board prob. Any help?
If the LCD panel back light is not lit you have a bad LCD panel. If the back light stays lit when the set is turned on then you almost certainly have a bad main board since you have already replaced the power supply and T-con.
Aug 17, 2015 | LG Televison & Video
I have a Samsung tv pic does not work but have sound..model #40pfl3705D/f7. What part needs replaced...t-con board?? And if it is.. how do I know which board is t con board?
Here's how you determine if it's the T-Con board. Turn the TV on and shine a flashlight on the screen. If you can see the program you're hearing then the T-Con board is OK. The inverter board controls the back lights. This board is the problem.
Mar 25, 2015 | Samsung Televison & Video
Dont show no pic just a whiye screen
I assume the sound is still there.
The most common (but not always) solution to a white screen is to replace the T-Con Board. Check your T-Con board before ordering to ensure you get the correct one. It should be something like "81-01306A"
Nov 13, 2013 | Samsung LN-T4042H 40 in. LCD HDTV
TOSHIBA 32bv500b screen stops working sound works fine
I'm having a hard time finding any parts for the set besides the power supply board. The T-Con is usually located top center on the back of the LCD panel. It will be under a metal cover. Sometimes, the t-con circuitry is built onto the main board. If this is the case with yours, you will have to order the main board. Feel free to send me a pic of the back of your set.
info@back2lifeelectronics.com
Jan 06, 2013 | Toshiba Televison & Video
Got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
Feb 27, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
JVC LT-42X788 42 in. LCD HDTV Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
