Question about Toto Home
My Toto seat snaps when you sit on it. This happens on one side tho it is moving and appears to be a break in the top and bottom sections which then allows the top section to snap down over the botto
Called Toto but they want me to send it in. I need my toilet.
    Sergeant:
  • 274 Answers
Take the seat cover off and send it in and get a replacement one at walmart while your waiting
Posted on Nov 20, 2014
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
jeff_drakesr
  • 155 Answers
SOURCE: my toto toilet flapper comes down too fast not
Shorten the chain link so that when handle is pushed down the flapper stands more upright. Dont shorten to much so that it wont seat all the way either. Good Luck and a Great Day. Please rate 4 THUMBS UP if this was helpful.
Posted on Apr 01, 2010
  • 299 Answers
SOURCE: I have a toto ultramax. the water keeps running
It is a little stiff but you won't break it. Just turn the cap counter clockwise (left) about an inch and it'll come right off. Put the replacement cap on by doing the reverse and it should be good to go. I have 7 of these toilets and they all needed cap replacements within 2 years. When you change it be sure to flush any sedimant out of the valve body as that's what usually causes the problem. Once you have the cap off hold a small pail or large cup upside down over the valve body and turn the water on for a few seconds. The cup will keep the water in the tank and the body will be cleared of sediment. After changing a couple and on the recommendation of the local Toto distributor I decided that it would better to just replace the whole valve with a FluidMaster unit (about $8 at Home Depot). The Fluidmaster units have been working fine for 6 years. It takes less than 20 minutes to replace the whole valve but is, of course, a bit more work than changing the cap.
Posted on Apr 18, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my toilet handle turns but the toilet won't flush.
Your attachment to the flapper valve broke...it is either a plastic connection or a metal chain type connection...easy fix.
Please rate me
Posted on Oct 14, 2010
Toto toilet seat slides to side
you have to tighten these from the bottom of the bowl...use open end wrench or cresent to do
Oct 28, 2012 | Toto Round Maple SoftClose Toilet Seat...
Rightside, rear window motor failed. or the mechanical part perhaps. what i want to know is how to get to that part of the car. The driver seat behind the panel. Thank you wery much! Patrik
Long job and not for the faint of heart.
Open roof to rear.
Pull up on rear seat bottom and remove it.
Remove center panel.
Remove three Allen head bolts down behind seat cushion back.
Lift off head rests...pull up.
Raise top just enough to make side flaps flip up.
Remove nut at top rear corner.
Remove Nylon/plastic push lock rivet where seat belt goes through panel... top corner.
Pull panel off mounting pins...will sound like your breaking it !
Lift panel to access seat belt bolt and unplug Flip-Up panel motor.
Remove cable from it's clip.
Remove loom thro' panel.
Pull seat belt thro panel.
Set panel to one side.
Remove Torxs bolts around black plastic panel for speaker.
Unplug speaker.
Pull loom thro' hole.
Remove two Allen and 5 hex bolts where window would come out. if it worked.
Pull up plate and remove rubber seal to one side and then remove plate. remove two nuts at bottom of regulator and one half way up towards front.
Lift regulator and window glass up thro' top to gain access to three nuts holding glass tho regulator.
Lift out window and then regulator....little maneuvering and levering required.
FYI....Take digital pictures as you remove stuff for later reference.
New regulator and glass is around $600.00 from dealership and only the dealership.
Jan 12, 2011 | 2004 Volkswagen New Beetle Convertible
The keys are locked in the trunk. a lock smith opened the doors to the car but could not open the trunk. The alarm system went off and now the trunk switch will not open the trunk. How can we get into the...
Remove the back seat. Back seat has two parts, bottom section that you sit on and back section. In between the bottom and back sections there are two bolts, feel for them and then remove. Once removed the bottom section can be pulled out. Then you can see the hinge at the bottom of the back section, remove bolts at the bottom and then you can lift up and access the trunk.
Jul 10, 2010 | Hyundai Motor 2002 Elantra
I want to download its software how can i do it?
By software do you mean the phones software/firmware?
If so...
you will need to download EFS, find that here and an alternative version here (use this one if your pc flags the first one as a virus)
  • First, on your pc's desktop, create a new folder by right clicking in an empty space and choose new - folder, name this LGAPP or something that you will remember.
  • Now open the EFS program, but don't connect your phone yet. You will see a large empty screen with an "explore" button on the top bar, press this.
  • A smaller empty box will open in the middle, click cancel on this one.
  • You will notice that the screen is now split into 4 sections. In the bottom half is your Pc's files, the top half will show your phones files once we are connected.
  • In the bottom left section, find your desktop where you saved the new file that you named before. Open the desktop folder and then open the newly named file, the bottom right section should be empty.
  • Now, put your phone into "Data mode" by going to Settings-Phone settings-Connectivity-USB connection mode-Data mode. Return to the home screen.
  • Now on EFS close the first window so you are back to the empty screen with the explore button at the top. Click "explore" again, the small empty box will reappear.
  • Now when you connect your phone you will have about 3 seconds to tick the box that appears in the top left of the small box and then hit connect in the bottom right of the small box. If a warning appears and says something about a port, just disconnect and reconnect your phone.
  • Once connected you will see your phones files in the top half of the screen.
  • Make sure that the bottom half is still showing the folder you named earlier.
  • In the top half, right click LGAPP and click re-name, LGAPP(text) should turn blue. Now type TOTO and click in an empty space until it is no longer blue
  • Right click TOTO and choose refresh. This enables you to copy the protected files in your phone
  • DO NOT RENAME TO SOMETHING BLANK!!
  • Your phone will disconnect itself
  • You will get a yellow screen don't panic, just reconnect
  • You will notice that a "ghost" LGAPP folder has appeared, ignore it
  • Now right click on TOTO and choose "read", after a few seconds your files will start to copy to your pc, this will take about 40 minutes, so sit back, go watch tv or somethin just don't turn off your pc or your phone, in fact, don't touch either.
  • Once this has finished you will have a copy of your own firmware backed up. Save this at all costs, put it on a memory stick or something.
  • In the top left section scroll all the way to the top and click the folder with no name (very top one) you should now see TOTO again in the top right section.
  • Right click on TOTO and rename back to LGAPP, then right click and refresh again.
  • Now click on "Disconnect" on the middle bar and choose "yes" from the pop-up. Your phone will now reboot. Thats it your done.
Or go to the LG website if it's Sync software you are after.
Jul 06, 2010 | LG KU990 Viewty
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
How do I get the old toilet seat fastener bolts out of the holes? I have a replacement seat but I can not figure how to get the old bolts out of the toilet. There is no access to the bottom side of the...
On top if you look closely you will se that where the hinge is you can lift up a plastic cap and see the top of the screw. From there you can remove screw. It should be a flat head screw.
Good Luck
Nov 04, 2009 | Toto Toilet Onepiece Ultramax ...
I dont know how to install stereo speakers in my citroen saxo VTR near the rear seats. how can i do this?
First you have to remove the old ones...
You cannot just clip out the rear speakers, as the cover over them is attached to the rear panel (2 door Saxos)
In order to take out the rear speakers, from what I remember...
1) Take out rear seats
-Get yourself in the car through one of the front doors
-Once inside face toward the rear seat
-Reach for gap between where the upper and lower parts of the seat join
-Pull the bottom half up and towards you
-Once it is vertical lift straight up to detach from pivot
-Get it out of the car to give you space
2) Undo 2 bolts
- Having just removed the lower part of the seat there are now 2 bolts visible 1 located each side of the car, next to the rear speaker panel.
- Undo the bolts, they are long so require lots of twisting until free
- Remember where the washer sat and place in safe location out of car
3) Lift up rear window seals
- Open rear windows
-Lift up the rubber seal which lies on the bottom part of the window
-(It is attached all the way round the window trim, only lifting it up is neccessary)
4) Remover upper seatbelt bolts
- Locate rear seat belts (side belts only)
- Locate top of seat belt fixing point
- Remove circular plastic covering on top joint of each belt (1 each side)
- This reveals seat belt joint bolt (1 each side)
- Undo bolts and place safely outside of car
- (Same for front seat belts required)
- Locate front seat belts
- Locate front seat belt joints at top of belt.
- Remove circular plastic covering (1 each side)
- This reveals bolt (1 each side)
- Undo bolt and place in safe location
5) Lower rear seat
- Open the boot
- Clamber in
- Locate where rear seat meets plastic trim (each side of car)
- Locate small plastic lever (each side of car)
- Push small plastic lever towards the front of the car (both sides same time)
- Meanwhile push rear seat gently towards front of car (helps if have a friend)
- This will lower seat
- (You do not want seat lowered completely, once seat is free in movement leave resting in normal position)
6) Remove rear speaker panels (requires trusted + competant friend)
-Friend Get in car sit where rear seat was on driver side (for space)
-You sit front seat passenger side
-You locate where rear speaker panel ends beside front door
-You pull rear speaker panel away from end at door towards opposite side
-You will notice part of rear speaker panel detach from car
-Friend and You pull off remainder of speaker panel from its poppers
-Notice lump of plastic preventing complete detachment from car
-Careful to prevent damage Friend and You need to move rear speaker panel towards front of car and up
-Remember plastic will flex, but is also capable of snapping
-Manipulating this action will get rear speaker panel detached from car...although still on the seatbelts themselves.
Notice how speaker is joined to hidden part of rear panel, rather than metal body work.
To remove rear speaker undo the 4 torx screws holding speaker in place, alongside wire joint (wire with plastic adaptor at end)
Do what you needed to do, and then return car to normal state by effectively reversing the above instructions.
(I accept no liability for any action you undertake from following these instructions.....yadda yadda)
If any problems contact a Sax-p I.C.E section expert, or if incounter any difficulties that the above cannot solve, any car audio installer can help, alongside most garages, including Citroen Dealerships.
The instructions above probably took longer to type than to actually perform, estimated time for completion is 40mins-1 hour.
Oct 24, 2009 | Car Audio & Video
The toilet seat on my TOTO toilet has come off. Has something broken that I can repair or do I have to buy a new seat?
are you sure it is broken or the screw has come loose check it out again does not break very easily
Sep 26, 2009 | Toto Washlet S400 for Power Gravity...
My baby pulled the caps lock key off the lap top can i fix this at home
These require VERY careful technique to re-install the keytops.
USUALLY they sit on top of a little "scissor" arrangement that have tiny plastic parts. Getting the little pivots back in place can be tricky and it can be easy to break the parts. You should be able to find somebody that can do it for you.
Sep 04, 2009 | Compaq Computers & Internet
Home Logo
87 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
