Question about Pioneer Car Audio & Video
Bluetooth will not connect
Blue tooyh just saws no service
    Sergeant:
  • 274 Answers
Go to your service provider to get it fixed
Posted on Nov 20, 2014
How many mobile phones can be connected at once by blue tooth with Parrot v5.29C?
The bluetooth specification allows up to seven devices to connect, but it's not straightforward, as it is dependent on the type of device and the service profile it provides. For example, you can have a bluetooth keyboard, mouse, and headset connected at the same time, and an A2DP (Advanced Audio Distribution Profile) device to stream music, but you can't have two devices that performing the same service profile connected at the same time.
Jun 07, 2016 | Parrot Cell Phones
Can I connect bose speaker to Sony blue ray via blue tooth
Is your Bose speaker a Bluetooth speaker ? Does your Sony blue ray player have Bluetooth ? You can connect the two only if Both are Bluetooth devices.
Feb 15, 2015 | Sony Televison & Video
I have zebronics blue tooth.. it doesnot require any drivers.. but still in windows 7 it showing some blue tooyh pheriferals driver not found.. Please help me
it may not have compatability with Win7-- check the mfgr's website under the software requirements,,,
Best regards
Ck
Feb 16, 2011 | Computers & Internet
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
How to transfer Motorola Razor V default ringtones
you can transfer it from your computer with the ring tones saved on the system,or via mms message sending ring tone form razor to your lg phone aso you can use blue tooyh to transfer ring tones
Dec 18, 2009 | Motorola Mobility RAZR V3
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
Can't get my bluetooth to work with my phone anymore.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 31, 2008 | Jabra BT350 Bluetooth Headset Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Not able to connect Jabra BT 125 to Laptop
Correction to the above note...
You can connect your Jabra 125 to your computer's audio output and listen to music via the ear piece. You need to make the adjustments in the control pannel. Set the audio/sound output to the blue tooth. You also need to sync the earpiece to the pc via a dongle or bluetooth adapter on the pc. Works great...
Jimmy
www.CLSONLINE.org
Feb 16, 2008 | Jabra BT125 Headset
Car Audio & Video Logo
44 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
