Question about Sunbeam California King Arlington Heated Electric Warming Blanket Mattress Pad,
I have a King blanket which I purchased at Meijer on 01/19/14.The right side failed to heat today 11/20/14
Model #2704577174 I have checked the blanket electric hook-up and all was OK.I turned on the highest setting on both sides and only the left side heated up.
EwingElect
  • 276 Answers
SOURCE: Sunbeam Electric Blanket Model 972 A5 Type 692
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Posted on May 26, 2010
  • 377 Answers
SOURCE: I received this electric blanket
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Posted on Sep 19, 2010
fasteddy23
  • 17 Answers
SOURCE: What do you do when an electric blanket heating control has had something spilled on it?
Hi Ann; Make sure the power is off,Then see if there are screws to take it apart,if not you may be able to pop it open with A screw driver. If you get that far take A Q tip and dip it in rubbing Alcohol and clean parts inside, wait 5 Minutes for Alcohol to evaporate and re assemble. Plug in and try it. Hope this works for you it worked for me but it was very hard to get it apart.Good luck
Posted on Nov 07, 2014
  • 22 Answers
SOURCE: How do can you clean an electric blanket heating control where the dial is stuck and won't turn.
Wd 40 spray it down really good then wipe excess. Let dry
  • 3107 Answers
SOURCE: my blanket keeps on heating at off. I have to unplug it to stop it from heating just on one side. I just received it 2 days ago.
There is a problem with the thermostat. You need to return it and get a replacement.
Posted on Jan 24, 2015
My king size blanket won't heat the control is on but not heating what to do
You have a break in the connection or a break in the heating element. Either way, you need a new blanket.
Mar 18, 2016 | Heating & Cooling
I need electric cord for Winter's Tale Blanket-Q Model#0906P04CN -Q
I too amlooking for where I can get a remote for a Blanket K 0906P04CNk
Feb 20, 2014 | Winter's Tale Microplush Electric Blanket...
Winter's tale electric heating blanket flashing "F"
I\'m having the same problem as Jenn. Tried unplugging it and left it for a day. Both sides are now not working. How can I get it to work again? Husband is having a hissy. Please just tell me what to do. or tell me how to download the manual. Haven\'t had this for very long 2 months. if any help.Mary Ellen I did love this when it did work.
Nov 19, 2013 | Winter's Tale Microplush Electric Blanket...
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
King size dual control electric blanket blinks and displays F2
you may have a faulty connection or bined wire on the blanket they do have a switch that shot off for any reason..you can't do anything unless you open it and check
Nov 08, 2009 | Heating & Cooling
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Dec 17, 2008 | Heating & Cooling
Sunbeam California King Arlington Heated Electric Warming Blanket Mattress Pad, Logo
99 people viewed this question
Top Sunbeam Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sunbeam Furniture Expert? Answer questions, earn points and help others
