Maytag 3000 washer takes 2 hou rs to do a regular cleaning cycle
    Problem Solver:
  • 10 Answers
Sounds like timer switch change to different setting and try again if same its timer switch
Posted on Nov 20, 2014
SOURCE: MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Posted on Jul 15, 2008
SOURCE: belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Posted on Oct 06, 2008
SOURCE: Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Posted on Oct 28, 2008
SOURCE: dryer takes 2 or 3 cycles to dry clothes
dry turn very slow
Posted on Dec 03, 2009
  • 46 Answers
SOURCE: Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Posted on Mar 19, 2010
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it...
    oooow,,,temper temper,,,,take a deep breath,,,
    i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
    then go out and find a big stick,,,and batter it with the stick,,,
    this realy wont help fix it,,but it will make you feel soooo much better?
    Jul 12, 2010 | Maytag Dryers
    Will get a bad oder from inside if not run daily
    Most likely you have an accumulation of waste in the waste pipe or filter that takes water out of the dishwasher to the waste pipe. Check and clean this regularly. In addition, you can buy dishwasher cleaning solutions, which are usually just a small bottle that gets placed int he dishwasher alone and the washer is run through a normal cycle. This helps clean the washer out and deodorizes it as well, however, the odor is probably from a dirty or clogged filter to the waste pipe/tube.
    Jul 15, 2009 | Maytag Dishwashers
    Humming or buzzing during wash and spin cycles.
    it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
    Jun 20, 2009 | Maytag PAV2300 Top Load Washer
    Not cleaning dishes in model # mdb6000awb maytag
    One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it not to drain and reusing the old water to wash. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
    Apr 10, 2009 | Maytag Dishwashers
    Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
    Washing Machines Logo
    Top Washing Machines Experts
