Question about Hisonic Audio Players & Recorders
I have the Hisonic HS-8200. When I received the system though, one of the microphones tries to work on the 3rd channel, but it won't produce any output and actually interferes with the mic that is al
I have the Hisonic HS-8200. When I received the system though, one of the microphones tries to work on the 3rd channel, but it won't produce any output and actually interferes with the mic that is already on channel 3! What can I do to fix this problem and get this mic on channel 1 like it's suppose to be?
arthurroger
  • 170 Answers
SOURCE: AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Posted on Dec 03, 2008
  • 11 Answers
SOURCE: Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Posted on Mar 01, 2009
  • 611 Answers
SOURCE: wireless microphone receiver ready light or audio indicator nogo
It is definitely a Sync issue.
1) Make certain the microphone is ON and the light on it is green.
2) Remove the battery cover from the microphone.
3) point the **** end of the microphone (where it says Sync) toward the Sync button the receiver (about 6-8 inches away).
4) Press the Sync button on the receiver. You should notice the light on the microphone flash.
If this still does not work, call Shure Applications at 847-600-8440.
Posted on Nov 18, 2009
  • 417 Answers
SOURCE: shure sm58 just started outputting very low volume
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Posted on Apr 15, 2010
  • 16 Answers
SOURCE: Crackling Microphone
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Posted on Aug 07, 2010
Hisonics microphone manual HS 938
Battery compartment is in the base the microphone. Hold the base upwards, grip the mike below the head and turn the base anticlockwise.
Not yours, but same make.
http://hisonic.net/downloadable/download/sample/sample_id/9
Apr 18, 2017 | The Audio Players & Recorders
I received my Asus HS-101 PC Headset today and plugged them in - I can hear sound though the microphone doesn't work for some reason. Any ideas?
You plugged both the headphone part in and the mic part in separately, right?
If you right-click on the speaker icon, you can select the "recording options". There may be a checkbox for "+20db" for the microphone as well as a volume slider. Try both.
May 14, 2015 | Radio Communications
I need to download a Manual for HS-569B system
Try Hi sonic's website or their local agency where you stay
Mar 16, 2014 | Hisonic HS596B VHF Stage quality Wireless...
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
My Samson Wireless Lapel mic system has stopped working. First the reception became intermittent... a few days later stopped working altogether. I was hoping that it was just a bad set of...
There could be a number of reasons for this problem you will need to work through them from one end of the system to the other to diagnose.
Start with a bit you know is working.
  1. Look at the receiver unit first. Do the indicator lights come on when you switch the microphone on? If yes hold the microphone belt pack about a couple of feet from the receiver and move it from one side to the other. Do the lights flicker? If it is a 2 channel (dual diversity) model -do the A and B channel lights flash on and off to indicate that the receiver is switching channels? If they do the problem is unlikely to be the microphone or belt pack.
  2. Is your amplifier/ computer/ audio system producing sound from other sources (e.g. radio etc)?
  3. Unplug the output lead from the back of the receiver and plug a cabled microphone or other sound source / instrument to it to test the cable.
  4. It may be some sort of external interference. Most of these sort of microphones can be switched to different frequencies. Try changing frequency (usually a little rotary switch on the back of the receiver and inside the battery pack - will often need a small flat bladed screwdriver to operate it) and make sure that there is a clear line of sight between receiver and transmitter units with no large lumps of metal or electrical devices in between.
  5. Do not use re-chargeable batteries as they almost never achieve an adequate voltage. Always use Duracell Ultra or equivalent.
  6. The capsules and cables of lavalier / lapel microphones are very prone to failure. Try removing the microphone jack lead and plugging in a different one . If you don't have another microphone try a simple audio lead - maybe a mini jack-plug to standard 6mm jack and connect an electric guitar or other sound source (or just touch the bare plug contacts at the other end of the lead to see if it creates a sound) . Does it work? If it does then it is possibly the microphone itself rather than the belt pack. These microphone capsules are not repairable and mending the cables / jack plugs can prove very fiddly, (lost are moulded units and cannot be dismantled anyway) however replacement microphone capsules are not very expensive (about £16-£20 in the UK) but before you replace it see steps 7, 10 and 11 below because it could just be a problem with the jack socket on the belt-pack
  7. Look at the jack socket itself. These often attach to the case of the belt-pack with a threaded ring that screws onto the socket unit. Sometimes the screw ring can work ever so slightly loose - which means that the jack plug doesn't quite go far enough into the socket to make a proper electrical contact (we had exactly this problem with a different brand of lapel microphone).
  8. If the tests at no 6 don't find the problem examine the wire aerial on the belt pack carefully. Sometimes the central core of the aerial can get cracked by frequent bending (usually when people stuff the belt pack in their pocket). Try twisting the wire backwards and forwards gently. Work all the way along it's length - does this make the unit work -albeit intermittently?
  9. Dismantle the belt pack to check that the aerial wire has not got broken off the circuit board.
  10. While you are in there check that the wires to the microphone jack socket have not got broken off or stretched so that the screen and core are shorting out.
  11. Put a battery in the belt-pack and try touching the contacts on the microphone input jack socket with a small screwdriver or other metal object - does this produce any sounds? If so it may be that the contacts inside the socket are bent and therefore not touching the pin of the jack-plug. Some careful re-bending with a thin probe may solve the problem.
  12. If you have got this far you can be fairly certain the fault like in the microphone capsule because you have eliminated every other possibility
Jan 30, 2011 | Samson Audio Players & Recorders
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Mic troubles
check antena connections first
Mar 27, 2007 | Hisonic HS596B VHF Stage quality Wireless...
65 people viewed this question
Top Hisonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hisonic Audio Player and Recorder Expert? Answer questions, earn points and help others
