Question about Coffee Makers & Espresso Machines
Hi.i have a 157 error on WMF coffe machine.what is that???thanks
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Error code F187 on a wmf 1200s, any suggestions on how to fix it
KOD BLEDU CODE ERROR F87 F187 W WMF 1200, WYSTARCZY WYJAC Z BOJLERA CZUJNIK TEMPERATURY PRZELUTOWAC NA NOWY ZA 1,5PLN /0,4EURO ,79f38919-05c3-4d8a-b59d-1f0cb67501ce.jpg
Sep 15, 2014 | Washing Machines
My wmf prestolino displays error code 187 when i turn it on. What does this mean ?
change the termistor from the top of the biger boiler with NTCM 10 ohm and that is the best solution 100% works
Nov 19, 2013 | WMF Coffee Makers & Espresso Machines
WMF PRESTO STUCK
You do the Descaling and set the water hardness below 5
May 11, 2013 | Coffee Makers & Espresso Machines
We have the error 5 at the WMF coffee machine . please help what we do?
Just had the same problem today.
It seems that it's the grinder inside that's not placed correctly or dirty or jammed... just get the "brownish" thing out... See that everything turns as it should, that it's quite clean and put it back. Restart machine and then it should work
Jun 04, 2012 | WMF Coffee Makers & Espresso Machines
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
