Question about Samsung Televison & Video
Why does my samsung tv overheat and then shut off?
Do you have a dlp?I need to know.
Posted on Nov 21, 2014
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Samsung dlp tv shuts down and lamp overheat light comes on
this would be a answer for samsung 1800-726-7864
Jun 07, 2012 | Samsung HLS4266 TV
Picture on Samsung TXL2791F gets smaller after a few minuets
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat.
Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
May 24, 2012 | Samsung TXL2791F 27" TV
SAMSUNG HL-S5687W My Samsung DLP is shutting itself off shortly after having been turned on. This has been occuring consistenly for the last 24 hours now and I can't get the unit to stay on. This has...
its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help in solving the problem......
Dec 21, 2010 | Samsung HL-S5687W 56" HDTV
TV SHUT S ITS SELF OFF
Is the unit free of dust and debris from dust? If its overheating there are may factors that play in this
1. fan spinning but not enought RPM rotations per min ( not fast enough)
2. room temp
3. dust
other then that some capictors must have exploded inside withc will cause a overheat.
Apr 22, 2009 | Samsung HLR5064W DLP Projection TV
SAMSUNG 61" DLP, HL S6187WX keeps shutting off
Make sure there is plenty of air flow around DLP, If nothing is restricting the air flow then the fan may have a problem.
Dont use your DLP until the problem is diagnosed by a tech.Not only will you shorten the lamp life you can do unrepairable damage to the TV.
Call Samsung to see if the TV is still under warranty.
Feb 02, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Overheating of 56 in projection screen, samsung
do you get any blinking lights? if so how many times and how many lights?
Dec 13, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
