Question about NutriBullet Pro 900 Series
Why is my plastic container not locking in, motor starts when pushed down but can not twist to lock in
    New Friend:
  • 32 Answers
The micro switch or locking part is moved
Posted on Nov 29, 2014
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
How to unjam the lid to an OXO Good Grip Pop Container
replacement parts can be found easily on amazon. here: Amazon com OXO Good Grip Pop Container parts I hope this was helpful. Cheers
Mar 20, 2013 | Oxo Good Grips POP Rectangle Storage...
Backfire on cold start up blows vacume plug off of intake
PCV valve blocked maybe causing a pressure build up
May 24, 2017 | 2001 Chevrolet Blazer
I need to know the order that you tighten the rocker arms.# 1 piston is at tdc, which int exh valves need to be tightened before i rotate the engine.then which follow suit.i replaced the pushrods so my...
adjust the valves in the order the cylinders fire one cylinder at a time turning the motor for each,slightly loose.start the car and let it warm up a bit then adjust the valves while running.most techs go down one side then the other. you don`t say what motor it is,but some motors valves rocker arm nuts are torqued so you can torque the rocker nut for all the cylinders,then start the car and let it run so the lifters will pump up and thats all you have to do with this type of system,as there is no other adjustment to do.
Apr 24, 2011 | Ford Mustang Cars & Trucks
What type of fitting attaches engine oil cooler lines to left side of radiator on 1995 g20 full size chevy van
push connect fitting to take appart back up plastic retainer ring (looks like flat washer)
then ther is a nap wire clip that you can push in to release locking tabs if to dirty pull it
straight out (pick hook works fine or pliers if you cn reach
then pull line will twisting back and forth untill free
new line should come with new retainer washer and wire clip
installed wire clip first then push line on until it looks in installed retainer
start motor and check for leaks
Apr 02, 2011 | 1995 Chevrolet G20
How to change the toner cartridge?...please I need help!
1 Open the top cover.
2 Open the front cover.
3 Lift the process unit, together with the toner container, out of the machine and place it on a clean, level surface.
Do not stand the process unit on end and never expose the drum to normal lighting for more than five minutes.
4 Pull the lock lever towards to the UNLOCK position then pull the toner container release lever to the right.
5 Gently remove the old toner container. Put it in the supplied plastic bag and dispose of it according to local rules and regulations.
6 Shake the new toner container horizontally 5 or 6 times to distributed the toner inside.
7 Remove the orange protective seal.
8 Align the knob on the left side of the container with the groove in the process unit and insert it. Push on the PUSH HERE marks until the container clicks into place.
9 Push the lock lever back into its locked position (away from you).
Clean the charge and registration roller.
Refer to Cleaning the Charger and the Registration Roller on page 5-4.
Feb 22, 2011 | Copystar CS-1820 Copier
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
Bought a new Fluidmaster from Home Depot and lost my instruction sheet in english......Colony FitRight two piece toilet. after flushing, the water still runs (most times) into the refill tube. It looks...
First, turn water off at wall valve under toilet. Next, find the plastic ring/collar almost at the bottom of the fluidmaster's shaft inside the tank. Pull UP on the locking ring/collar until it comes loose. This releases the upper shaft from the lower shaft and it can be pulled up or pushed down on the lower shaft to make the entire shaft taller or shorter. It has to be pulled or pushed over some plastic grooves, so it may take a bit of twisting and/or moderate force to move it. You must LOCK the ring/collar back down to the bottom of the upper shaft before turning the water back on. Locking the ring back down may require a bit of twisting back and forth to line up those grooves inside the shaft. Only turn water back on after this lockring is pushed securely back down, after adjusting the shaft height.
Nov 10, 2010 | Home
How can I replace the driver side head light
the drivers side is a piece of cake... on the passenger side you need to remove the clean air intake. its a big piece of black plastic behind the headlamp. pulls right up. no big. but you'll have way less room to maneuver than on the drivers side. If you're doing both start with the drivers side bulb to get a sense of whats going on. it's impossible to get a sense of whats going on on the passenger side.
locate the bulb and remove the power clip from the bottom. there is a plastic lock that you have to hold down while you push to casing down. i had to use the tip of a screwdriver to put enough force on the clip-casing to manage this.
now the hard part:
there is a black ring that locks the bulb into place. this has to be twisted (when facing the toward the car) counter clockwise. molded into the plastic are the words lock and open. twist toward open. this is a massive pain in the a**. i had to use a screwdriver to get a little bit of leverage, make sure you're only twisting the black plastic ring and not the bulb. the bulb does not turn.
once the ring is removed the bulb twists and comes right out.
follow the directions in reverse making sure not to touch the new bulb's glass with your fingers. apparently the oil from your fingers can shorten the bulbs life... or so i've been told.
it takes a little while and that damn lock ring is tough to get off. but its not that bad
Sep 19, 2009 | 1995 Honda Accord
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
NutriBullet Pro 900 Series Logo
63 people viewed this question
Top NutriBullet Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NutriBullet Office Equipment and Supply Expert? Answer questions, earn points and help others
