Question about Yamaha YSP-1 System
Leave the solution for yamaha ysp1 crackling when first turn on.
    Top Expert:
  • Yamaha Master
  • 74,243 Answers
Check for any loose solder terminals at its main power amp section circuit. Contact any service technician. Electro help
Posted on Nov 20, 2014
Cracking speakers when tv turns on
If other electronics are too close to a TV this is a common problem. Try moving the 2 items at least 2 foot away and see if that helps.
You may not want to leave them there, but at least you will know if that's the problem!
Mar 01, 2014 | Bose Cinemate Series II Speaker
Yamaha PSR 740 Volume knob crackles when turned and the sound cuts out when played at higher volume
There is dust in the sliding mechanism, which can be cleaned with a good electronic cleaner, which does not evaporate when drying. If that does not work, replace the volume potentiometer, the `part behind the knob.
Dec 05, 2011 | Yamaha Music
Drained old gas put in new new now its poping from exhust
Crackling and backfire is nearly always lean on fuel condition...
open your air fuel mix screw tiny amount at a time and test to see if helping this should clear up the popping..
Please note if you need to open the air fuel mix screw more than 3 full turns from fully closed then the easiest solution is leave the air fuel screw at 2 turns out from closed and increase the size of your pilot jet by one or two sizes.. they very cheap to buy few dollars each.
I would suggest if your only popping and crackling a little then small adjustment on the air fuel mix screw will cure it for sure
Being YZ I find an occasional pop or backfire when de acelorating is exactly how they should be if you don't get a pop or crackle every now and again then chances are it running to rich.
but if it is regular occurance then definitely needs fine tuning or larger pilot jet installed
good luck regards Jamie
Sep 09, 2011 | 2003 Yamaha YZ 450 F
My exhaust temp is extreamely high like the bike has a lean condition what does the jet setting need to be? On my 2001 yamaha yz426f. ,
jetting would be 45 pilot and 165 main jet but this changes dramatically depending what altitude you ride at - you might want to check your fuel air screw it should be 1.5 to 2.5 turns out from fully closed
If you are running to lean you will get a very big clue when you ride it the bike will backfire, pop and crackle every time you come off the throttle.
Also might be worth mentioning your header pipe on any YZ four stroke will always glow red especially when bike is idling. These YZ's are deigned for only one thing go hard and fast which gives them heaps of air flow for cooling but if you notice your header red when you pull over or leave it idling minute or two then thats pretty normal
Cheers mate let me know if you want more info etc... Good Luck!
Jul 27, 2011 | New Ray Newray Roadrider Coll Yamaha...
My center speaker crackles
Try connecting one of your other speakers to the centre channel on the amp to see if it is the speaker or the Reciever. If the speaker does not crackle then chances are the centre speaker is probably blown and will require replacing.
Jul 30, 2009 | Yamaha HTR-5730 Receiver
Yamaha YSP1
We have the same issue. I owned the unit for about 2 1/2 years before it quit working. The Yamaha YSP-1 has been sitting on my shelf for the last 2 years now collecting dust. If anyone finds a solution, please let me know
Dec 22, 2008 | Yamaha YSP-1 System
Yamaha YSP-1 System Logo
151 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
