Question about Health & Beauty
Where does black wire coming from coil go to
Nothing
  • 4 Answers
I am sorry, but I would need more information to help you. Which make and model scooter do you have? Which coil? Maybe a picture would help.
Posted on Nov 28, 2014
Need to know how to wire a coil on a Diamond I/C 20 hp briggs & stratton motor
Black wire should be an earth for the stop switch. needs to be attached to the switch but not directly to earth
Apr 20, 2013 | Briggs & Stratton Garden
I have a black and a white wire going to coil on 1991 dodge Dakota which one goes on positive side
the wires that come from the ignition go on the + terminal of the coil. As most earth wires are plain black I would say the white wire to the + terminal and the black to the distributor
Jan 21, 2013 | 1991 Dodge Dakota
How to test 95 Tacoma 2.4L internal distributor coil
You may need a shop manual for the procedure.
The black and red wire should be hot from the key. Other than that, you would need to know which wire sends a signal from the igniter to the coil to fire the plugs. The wiring diagram shows two wires from the computer to the igniter and nothing to the coil.
Aug 05, 2012 | Toyota Tacoma Cars & Trucks
I have fire going through the coil but not through the distributor
if you have spark at the distributor end of the coil wire and nothing coming out of the distributor wires then you may have a distributor rotor that has a small hole causing the spark to go to ground to the distributor shaft and not out the cap wires.you may have to take a very close look at it as it may only show as a black or grey track mark.or just change the cap and rotor if its been a while.
Nov 09, 2011 | 2001 Dodge Durango
I am trying to wire an hoa mechanically held contactor and need help i have a 120v feed going to a photcell and to the contactor i also have the load comming from the photcell to the contactor. so i have a...
IF the photocell is indeed 120vac and only has two connections and you wish it to control a separate contactor that controls something else and if the contactor coil is 120vac and has N.O. (aka normally open) contacts and you are controlling something that runs on 120vac, this is what you do.
Connect the hot/black wire of the incoming power and run it to one side of the Pcell and take another piece of black wire and run it from the other side of the Pcell to one side of the coil on the contactor. Wire the other side of the contactor coil to the neutral/white incoming wire.
What ever it is that you want to control goes on the contacts of the contactor. Hot/black incoming power connects to one side of a set of the contacts on the contactor. Take another black wire and go to the coil/motor/light whatever you want to control. The other side of whatever you want to control goes to neutral/white. Ground as necessary.
You can jumper from place to place to get what you need, ie the hot/black incoming at the Pcell can be jumped to the contact. White/neutral on one side of the contactor coil can be jumped to what you are controlling.
Here's what will happen when wired properly.
Nothing is running. The Pcell detects light and acts as a switch to connect hot/black to the coil of the contactor. The contactor closes because one side of the coil now has a hot wire and the other side has a neutral and the circuit is completed thru the coil. The contact's closing feeds a hot connection to the coil/motor/light (aka the load). Because the other side of the load has a neutral/white wire connection -
It runs.
It is your responsibility to not get killed or burn down the place if you don't have the skills to do this.
Sep 26, 2017 | Garden
I have a kawasaki mini ninja and i have a wire that is coming from the cylinder and the wire is by the spark plug cap and its not geting any fire is this because of this black wire??? and if so where does...
Follow the sparkplug wire to the coil. Chances are the small black wire is the power wire to the coil. In any event, find where the black wire plugs into another black wire and be sure it has a good connection.
Jul 13, 2010 | Motorcycles
Need coil wiring diagram
Contact points cover open.
Left side points are for cylinders 1 and 4.
Right side points are for cylinders 2 and 3
Left side points have a White wire coming from it.
Right side points have a Black wire coming from it.
One coil runs two cylinders.
One coil runs cylinders 1 and 4.
One coil runs cylinders 2 and 3.
No matter what style of ignition coil you use, the Black wire will connect to the Points. Whatever other color of wire they use, connects to the ignition switch.
BUT, check the specifications for the coils you're going to install. Connect the Negative side to the points. The Positive side to the ignition switch.
The Orange wire with a White stripe, coming out of the harness of the Suzuki Gs550 is from the ignition switch. It goes to a splice connector, and from there goes to two wires. The wires split off into one wire for each coil.
There is a White wire on the coil, that is used for Cylinders 1 and 4.
There is a Black wire on the coil, that is used for Cylinders 2 and 3.
Oct 21, 2009 | 1979 Suzuki Gs 550 L
COIL?
90 to 98 legacy (mine is a 98) coil should be the square-ish black unit with two sparkplug wires coming off laterally from each side--------sitting right on top of engine--middle of the silver colored alloy intake manifold--just behind alternator.
...The low voltage wire leads plug into the passenger side of the coil unit--covered with the flexible black protector--within which are 3 wires. Likely can tap here.
Aug 08, 2009 | 1992 Subaru Legacy
I hav an old 1978/9 honda 550k the coil wires have got seperated from the loom out of each coil comes 1 red 1 black from the loom 1blacb/red 1 yellow 1 blue with the ignition on the black/white becomes...
Hi nd welcome to FixYa,
On a Honda CB550K, wiring would be:
  • blue - from ignition coil to contact breaker;
  • yellow - from ignition coil to contact breaker;
  • black/white - to the ignition coils from the emergency switch (engine off);
  • red - from the center fuse of the fuse bank to the ignition switch;
  • black - ignition +12 from ignition switch;
  • black/red - I don't recall a black/red wire on the harness.
Good luck and thank you for asking FixYa.
Aug 02, 2009 | Honda VTX 1800 N Motorcycles
No current to the cdi box,but the light comes on when i kick it over?
if theres no current to the cdi but the light works then its either the outer coil or the stator coil is bad and the lighting coil still works.
May 26, 2009 | 1994 Honda XR 600 R
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
