Question about Korg Music
Halo my name is budi..i am an indonesian korg pa50 user ..my pa 50 was blank and only rised on display "ssd not present"..what should i do??
I have been tried to install os ,but its does not work
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
I work with computers rather than musical instruments, but I imagine with all the things keyboards do these days they are almost certainly computerised, and your saying "tried to install os" confirms this.
In computers "SSD" stands for "Solid State Drive". If there is an SSD in the PA50, then it is quite clear to me that it is no longer working properly and needs to be replaced. Confirmed by the fact that you can't install the OS.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 20, 2014
  • 5603 Answers
SOURCE: korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Posted on Feb 01, 2010
  • 5603 Answers
SOURCE: I am trying to get the LED darker so I can see it
Try as you might, there doesn't seem to be a contrast control on this unit.
Things to try:
Shielding from light.
Polarizer similar to those used for privacy on computer screens.
Try a color filter, possibly orange.
Maybe a good old umbrella as silly as it sounds... there just isn't any way to darken the display.
The display by the way is NOT and LED, but a LCD on this unit.
Posted on May 15, 2010
  • 5603 Answers
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
Posted on Jun 25, 2011
  • 5603 Answers
SOURCE: dear sir... i have a
The key contacts are dirty on those keys. The contacts are conductive rubber "pills" in silicone domes that are pressed onto circuit traces an a board under the keys. One can clean these using ONLY 99% isoprophyl alcohol and Q Tips, HOWEVER: the disassembly to access the contacts is NOT for the inexperienced person. Each key has TWO contacts and one makes before the other and that is how they measure key velocity. When one contact fails, then maximum velocity usually results. You best take this to a repair shop and have all key contacts cleaned. DO NOT use normal contact cleaners as that will destroy the contacts.
Posted on Aug 01, 2011
  • 1212 Answers
SOURCE: I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Posted on Mar 30, 2012
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Dec 13, 2013 | Korg Pa50 Professional Arranger Keyboard...
How factory setting korg Pa50 sd
Please see "Loading Korg Pa50SD's Operating System" below for
instructions on how to load the operating system.
Oct 04, 2013 | Korg Pa50 Professional Arranger Keyboard...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
Bulk dump to another pa50sd
*** fac o resetare generala la pa 50 sd
May 27, 2012 | Korg Pa50 Professional Arranger Keyboard...
Korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
FACTORY RESET ON KORG pa50SD
i use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Apr 02, 2012 | Korg Pa50 Professional Arranger Keyboard...
Hi Iam using my korg pa50 as the master keyboard ive connected the midi cables to my other keyboard which is a yamaha psr9000 I cannot play the chords on the pa50 using the styles on the psr9000 is there...
Jun 25, 2011 | Korg Pa50 Professional Arranger Keyboard...
Music Logo
82 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
