Need cable from dc 6v on left speaker to wall outlet
    Sergeant:
  • 271 Answers
WALMART OR RADIO SHAFT HAS THEM WITH VARIABLE VOLTAGE OUTPUTS.
Posted on Nov 20, 2014
Where can i get a replacement adaptor
Radio shack, best buy or newark electronics.
Feb 15, 2016 | Audio Players & Recorders
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
May 11, 2014 | General Electric 3-5027a Portable Cassette...
Power requirements required are 6 volts dc at what amperage?
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
Nov 29, 2013 | Labtec LCS 150 Computer Speakers
Hiw many mA does the adapter for labtec lcs150 speakers need
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
NEED TO REPLACE POWER SUPPLY
Nov 12, 2012 | Labtec LCS 150 Computer Speakers
Batteries wear out very fast, I need a 6V transformer
You can use any power supply with the following requirments:
output 6vdc, 400ma, plug 5.5mm x 2.1 mm with negative center.
You can buy one from your local market or from this link. In the last case you will get some various connectors and you have to check for the one that is better fixing. Also beware the polarity of this connector, the negative point HAS to feed in the center of the connector.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 08, 2011 | Labtec SS-100 Computer Speakers
Need power supply -- what are compatible power supplies?
Take a look where the power-adapter connects into the speakers. Also, look on the "brick" of the power-adapter.
Look for 'AC' or 'DC'.
Look for '6V' or '9V' or '12V' or '18V'.
Look for the Amperage rating.
If 'DC', look for the small pictograms, either:
* ring-positive-post-negative, or,
* ring-negative-post-positive
With that information, check Thrift Stores, and then check the "big-box" computer stores.
Jun 09, 2010 | HP Compaq JBL Pro (401508-001) Computer...
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
47 people viewed this question
 Grubhead
Grubhead
