Question about Sunbeam All Season KING Premium Heated Mattress Pad with Two Heating Digital Controllers- 250 Thread Count 100 Cotton
Flashing "88" and will not stop
On and off
Model no. 7468 when winding bobbin, machine stops and flashes code 88. why is it doing this
Check the troubleshooting section of your owner's manual. Usually, it will have a list of more common error codes.
You can also search for the
make + model + "error code 88"
or contact the manufacturer.
Nov 12, 2016 | Sewing Machines
Why does my Singer sewing machine stop abruptly and flash '88' when I try to re-fill a bobbin?
the best place for an answer for this would be from a singer service agent who has direct access to singer technicians to get answers for problems new to him
It mat be something that you need to do before refilling a bobbin or it may be a service fault.
May 21, 2015 | Singer Sewing Machines
Digital satellite receiver stopped working
Receiver. Try a hard reboot. Unplug the power, wait a minute, plug it back in. If that doesn't work it may need to be 'reauthorized" by the company.
Mar 23, 2013 | Televison & Video
Why do i have 88:88 flashing on my washer (model EIFLW55HIW0)
Unplug the unit for 30 mins. then plug it back in.
Oct 21, 2012 | Electrolux EIFLW55I Washer
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
Refrigerator control panel
88-89 Flashing Reverse 9.
I noticed this occurs when the Ice Machine get jammed up.
Remove all ICE from Tray and Clean.
Press and Hold Energy Save+Alarm Button for 10 Sec.
Jul 18, 2010 | Samsung Refrigerators
Flashing Display
Go to your breaker box and reset the switch for the microwave.. that will fix it
Jun 02, 2009 | Sharp R-1480 Microwave Oven
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Sunbeam All Season KING Premium Heated Mattress Pad with Two Heating Digital Controllers- 250 Thread Count 100 Cotton Logo
93 people viewed this question
Top Sunbeam Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sunbeam Furniture Expert? Answer questions, earn points and help others
