Question about Dryers
Whend you put the iso-dri fuel system dryer how long you need to wait for the car get stared
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
My suv 99 yukon has a wire short somewhere it seems to be grounding out it runs at low voltage when idling but when go to rev it up it drains power to the point of stalling,i connected a wire from bat
I have a 1999 Yukon it died on my way to work I thought I was out of gas because my fuel gage stop working. I put gas in it and ever stared. Next day it stared up and died a block down the road. Fuel pumps turns on 'put gas into choke and it gust turns and turns . I see that I'm not getting spark no were not out of the distributor and other stuff that makes cars spark I change distributor cap and button fuel filter and no spark what can it be need of help bad ty Steve frommpeoria I'll.
Jan 20, 2014 | 1999 GMC Yukon
Need renault falt codes 188, 148, also esp fault
P0188 - Generic Type Powertrain - Fuel and Air Metering - ISO/SAE Controlled Description Fuel Temperature Sensor "B" Circuit High
P0148 - Generic Type Powertrain - Fuel and Air Metering - ISO/SAE Controlled Description Fuel Delivery Error
BOTH OF YOU CODES is the fuel system error, so, please check the whole fuel system carefully, and any questions, you can ask the 24 hrs live technical support Chrysler Diagnostic Tool, they will like to help you, good luck
Sep 12, 2013 | Cars & Trucks
What is the best setting to use to dry clothes
Medium or low heat and put a few DRY,clean towels in there.
AUTO moisture sensors will do the rest.
The HIGH setting is not good for the dryer or your clothing.
Always put in a dry article to speed the process up.
Permanent press w/cool down is good.
If you use the HIGH setting,you better be **kid and waiting for the clothes to be dry!
Sorry.
Aug 26, 2013 | Dryers
My 2005 malibu 6 cyl has 54000 miles and no pior problems or warnings i went out and started it and came inside while it warmed up and when i went back out about 10 minutes later the car wasnt running, and...
many ideas lol. sounds like the fuel pump may have froze up. was the tank below 1/2/? moister in the fuel can cause this. any way to warm the car? this would be my first step
Jan 24, 2011 | 2005 Chevrolet Malibu
Just dried a load of clothes and every thing worked fine. Put in another load to dry and says it is sensing. Nothing else happens
Here's a quick thing to try. Unplug the dryer, wait a minute and plug it back in. Try drying the clothes again. If this doesn't work, you will require troubleshooting from one of the category experts for dryers. Good luck.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
I have a 1992 hyundai Scoupe (this car wasn't on the list) with a 1.5L I was driving down the road check engine flashed on engine quit running I waited 15 sec. car stared drove about 1 mile same thing...
You'll have to get rid of that check engine light as it indicates a malfunctioning part. Whether you like it or not you'll have to take it to a shop to do a diagnostic check on it. Check the fuel filter or a relay that's associated with the fuel system. It seems to cut out when it gets hot, check to see if there are any relays in the fuel system.
Nov 18, 2008 | Hyundai Accent Cars & Trucks
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
