Question about Boss Music
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
I have found manuals for both and looking at these I can see no reason why they shouldn't connect to each other. I am not a music expert but deal with computers. I would suggest that you try the external amp connection to connect the ME-25 to one of the BR-800's inputs, and then connect the "line out" of the BR-800 to an amp. Also make sure that during the connection operation, all power to the four units is OFF and the levels are all set to zero. By doing this you can minimize any danger of overloads anywhere in the system when you do "Power on". To help you confirm what I have said, I give below the links to the manuals which can be downloaded in pdf format and saved to your computer for reference as you connect up, and for any queries in the future;
ME-25 Multi-Effects :- http://cmstest.roland.co.uk/assets/media/pdf/ME-25_egfispd01.pdf
BR-800 Recorder :- http://lib.roland.co.jp/support/en/manuals/res/39599043/BR-800_e04.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 20, 2014
CRTN
  • 716 Answers
SOURCE: I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: I need help with my Boss Micro BR. I want to
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Posted on Oct 13, 2009
  • 1137 Answers
SOURCE: how do i connect active speakers to a BOSS br 1600
I would come out of the line out jacks on the studio into the line in jacks on the speakers. Make sure both ends of the cables have the correct plugs on them. I'll include a link in case you don't have the correct manual:http://www.alesis.com/content1023
Posted on Mar 27, 2010
  • 9 Answers
SOURCE: Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
The beats you have programmed into the drum machine will not play through the midi cable. In order to do what you want you need to connect the audio output from the drum machine to the audio input of the br-1180. What you should then do is connect the MIDI out of the the br1180 to the midi in of the Dr5. This will allow you to start and stop the drum machine with the play button on the br1180. MIDI can be a complicated thing so be sure to RTFM about MIDI for both of your BOSS devices to understand what they can do to work together. Good Luck
Posted on Dec 14, 2010
SOURCE: I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Posted on Feb 14, 2011
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
Hello Alan.
Yes you can connect your ME-25 to the BR-800, there is no risk to damage any. it is simple, you may use both outputs of the pedal and send them via two normal 1/4 plug guitar cables to two of the channels of the DR (i.e. ch 1 & 2) to avoid an initial saturation of the recording preamp, set the input sens pot at minimum and the sliders very close to minimum as you try playing and looking the levels on the display and adjunting them to the optimum.
To connect the DR to an amp you should use the pair of RCA jacks named LINE OUT (R & L) depending of the amp you have there might be the need for a conversion cable or plug adapters. The out put of the DR is stereo, and if you want to use a guitar amp, commonly mono, you should mix both channels to send them to one input, this can be done by putting two 10 kohms resistors in series with each channel output and joining the other end to the input.
Good luck and best wishes
Nov 20, 2014 | Roland Boss BR-800 Digital Recorder
Boss br 800 driver windows 7
Uninstall any HP device and try it. Then reinstall the HP device.
Dec 16, 2012 | Roland Boss BR-800 Digital Recorder
Bought a new BR-800 Digital Recorder and I can't play the demo song on it. I have followed all directions, however am still not able to play demo song or even find it in the menu. Can someone hel
Remove power supply or battery for 5 minutes. Apply power while holding the on switch in, this usually resets most electronic devices to their factory default condition. Then look again.
Sep 03, 2012 | Roland Boss BR-800 Digital Recorder
I need operation manual for a Boss me-25 Guitar multiple effects
Manuals can be a pain to find,you might take a look at this,,turbo start page;(cms.rolandus.com/assets/media/pdf/ME25ts.pdf)
You have me curious,so ill keep searching.Used to be easy to find a
manual for everything.
Jul 28, 2012 | Roland Boss ME-25 Guitar Multiple Effects...
Can't download tracks from BR-800 to laptop
Go to this site:
http://www.vsplanet.com/ubbthreads/
In the forums tab, scroll down to the BR8 forums. There is software to convert the BR files to PC readable. You can find discussion there of where and what to get.
Jun 17, 2011 | Roland Boss BR-800 Digital Recorder
Hey i just got a boss br-864 and it was recording fine but now i cant seem to get rid of the distortion.Tried adjusting the input level and sensitivity but no luck.Would appreciate any ideas,thanks.
Troubleshoot. Try different cables, mics, instruments, etc to make sure that its the device and not something else.
Make sure you don't have any digital effects (compressors, guitar effect simulators, etc) activited.
See if there's a way to restore the device back to factory settings. Make sure you backup your recordings first.
Dec 31, 2010 | Boss Micro BR Digital Recorder
I have a Fender G-DEC Guitar amp and it has an output for recording, can I connect it to the BOSS MICRO guitar input? The Fender amp has many rhythm functions which I am very familar with, besides it has...
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Aug 15, 2010 | Boss Micro BR Digital Recorder
Music Logo
70 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
