Question about Car Audio & Video
Which front cable do I use for nhdnw56
Nothing as radio restarts
Hi i have toshiba tlp 260 only the front fan running and nothing else
Do a system reset, and then check.
System Reset
On the keypad, press the Menu key.
Navigate through the basic menu to the default setting menu.
Select Reset all
After all tests are complete turn the power off and disconnect all cables; including AC input cable.
Then restart the projector. Good lick.
Sep 10, 2016 | Toshiba Office Equipment & Supplies
I Have a BF-888S Two Way Radio, It Was Working Perfectly Fine Before i Re-programed The Radio, Now When I Turn It On Nothing Happens, I Let The Battery Fully Charge And Still Nothing, When I Turn It On And...
If it was working before you re-programmed it, it is possible that your programming did not take. Recommend reprogramming it using Chirp (available for free on Internet). Make sure your programming cable works and software is talking to the radio. If you downloaded the previous software program from the radio, make the appropriate changes and then upload.
If this is not working, please provide info about programming cable and software being used.
Good luck,
Jan 19, 2015 | Radio Communications
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
May 18, 2014 | Kenwood KDC-MP538U Car CD/ MP3 Player
I have no head lights, no radio, no pump to my windsheild washer fluid, checked fuses and relay swicht's and get nothing
I have the same problem except my radio works. To me it looks like the washer fluid and headlights are on the same relay but replacing the relay does nothing. I disconnected the battery and removed the computer from the front of the relay box to let it reset and everything seemed to work fine at first. After restarting the car 3 or 4 times, the problem returned. Not sure what to do...
Feb 02, 2011 | 2004 Dodge Caravan
2002 cougar. Turn key nothing not a sound.
sound like alternator quit charging the battery.check battery voltage.it should be 12.5 volts.if not charge the battery.remove and have alternator tested at auto zone or advance auto parts.dont forget to turn off radio when disconnect negative battery cable.
Aug 09, 2009 | 2002 Mercury Cougar
My pro 2096
I have same problem. First unplug and then turn radio on to clear any left over power. Open the radio by removing 4 screws on back, then 4 more screws to remove top of inner case. then you will see a white ribbon cable. This has either come loose or it is not lined up properly on the connector. There are tabs on each end of the connector, you will need a super tiny screwdriver like for use on eyeglasses to open the tabs. Slide them towards the display or front of radio to remove the ribbon cable. I then used some alcohol and a q-tip and cleaned the metal contact point. then I slid the cable into place, and being careful not to touch anything inside radio, turn it on and check display. It took some moving around for me but finally got it to come back. Then close tabs on connector to hold ribbon cable in place. It seems to be a common problem with this radio.
Jun 04, 2009 | Radio Shack Pro-2096 Base Scanner
2006 Chevy Tahoe Z71
when you hooked the battery back up did the post and the cable spark when they came to contact? is it possible you hooked it up wrong?
Jan 11, 2009 | 2006 Chevrolet Tahoe
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
