Question about Kodak W730 PULSE Digital Frame
Screen Buttons Are Disabled
Rest Frame to factory settings
I have disabled buttons on my kodak pulse frame
If you are disabled, and use a walking frame, you should be able to get assistance from the Social Services department of your local council
Aug 17, 2017 | Kodak Photography
My Iphone4 is disabled, windows and iTunes does not recognize it, I want to factory rest it.
How to Unlock/Fix a Disabled iPhone - "I forgot my iPhone ...
? 7:34
https://www.youtube.com/watch?v=DjEw6DPGYiY
Jan 7, 2015 - Uploaded by Full Screen Ahead
4.) While holding the circle button at the bottom of your iPhonedisplay, ... Your PC or Mac will say "iTunes has detected aniPhone in recovery mode. ... says "Are you sure you want torestore the iPhone to its factory settings?
How to remove/reset any disabled or Password ... - YouTube
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
How to remove/reset any disabled or Password locked iPhones6S ... Thank you for watching, please feel free to comment, likethe video or subscribe to my ..... Iphone Disabled / Forgot Passcode iPhone Fix - Hard Reset for ...
Hard Reset for iPhone 6/5s/5c/5/4s - YouTube
? 3:21
https://www.youtube.com/watch?v=C8OCbVO8r6g
Jan 27, 2016 | Apple iPhone 3G
I forgot my password in my samsung GT-E2121B PASSWORD FOR PRIVACY LOCK
You can factory reset the phone which will erase every app text contact and photo on the phone but if you have them saved on a a SD card just remove it before the rest. Depending on the phone you will hold either two or three buttons. With phone off: Volume up, the home button if applicable, and then the power button. You will know you did it right if you see small print text at the top of the screen and it will boot to the restore screen. Using the volume rocker buttons toggle to factory and outs the power button. It may give you a warning yes or no toggle to yes and then it will restore the phone to it's original factory settings.
Jul 03, 2014 | Cell Phones
I have a trio stealth g2 and have been locked out how do you rest to factory settings
1. While the tablet is off, press the Volume Up and the Power buttons at the same time. Let go when the Android recovery screen appears
2. Press the Power button to bring up the recovery menu.
3. Using the Volume Down button, highlight "wipe data/factory reset"
4. Press both volume buttons at the same to select the option.
5. Scroll to and select "Yes - delete all user data"
6. Once the wipe is completed, select "Reboot system now"
Oct 25, 2013 | Tablets & eReaders
I have htc hd touch,& I can't pass the screen alignment. what should i do to continue normally ?
You need to hard rest your phone... follow the steps
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
3. Release the VOLUME UP and VOLUME DOWN buttons, press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
and still if the prob persist u can mail me at cellphonez99@gmail.com
Dec 02, 2010 | HTC Touch HD Smartphone
Ipod is disabled
Try this connect it to PC
While connected do a reset
It will bring it to it's original settings (Hopefully)
To do the rest while connected
1: Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.
2:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
This should start itunes if successful and ask if you want to restore to factory...
This assuming you have a newer ipod if it is older go here and do what I say but use a different reset while connected http://support.apple.com/kb/HT1320
Nov 08, 2009 | Apple iPod touch
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
I need to find how to reset my Panimage digital picture frame. The frame is not responding after showing the first image.
Hey,
I think this is how you do it, from the buttons on top of the frame hit exit several times until you get to the screen with options like, photo, file, music, etc. Once on that screen hit setup button and choose factory default. I believe that resets it.
Hope this works for you
Thanks
Nov 29, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Docutech 6100 fault code P09213
NOTE: Setting the Print Darkness to 5 will establish a baseline for the machine. After the setting is set to 5 and the fault code clears, you can then change the setting back to where you originally set it.
To set the Print Darkness to 5:
  1. Select [Printer Options] on the right side of the Touch Screen.
  2. Use the [Up] or [Down] arrow buttons on the Touch Screen to set the Print Darkness to 5.
  3. Select [Apply]. Make sure you select Apply or the machine will default back to Print Darkness 4 in the Printer Options screen.
  4. Select [Close] to close Printer Options.
  5. If available, select [Reset] in the Fault Frame.
The Fault Frame is a way the machine communicates with the user. The information the Fault Frame provides may be informational, such as explaining what features have been disabled, or provides instructions on fault clearance.
  1. Select the shaded Printer icon on the top of the Touch Screen to view the Fault Frame. The Fault Frame will open.
  2. Select [Reset], if it is available. If the Reset icon is not available, then follow the instructions in the Fault Frame instead.
Apr 14, 2008 | Office Equipment & Supplies
Kodak W730 PULSE Digital Frame Logo
149 people viewed this question
Top Kodak Photography Experts
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
