Question about Coby Televison & Video
When I turn my tv on after less then a minute the creen turn white you can see it but barely
Turned it off, unplugged it
  • Coby Master
  • 5,568 Answers
Could be that one of the power supply's outputs is going out of regulation.
While unplugged, remove the back of the set; normally 8-10 #2 Philips screws.
Locate a block of parts with several plugs plugged into it, this should be the power supply.
Look closely at components with a cylindrical case with aluminum visible on their tops.
Note that these parts have a scored 'Y' on the aluminum; this will split open to relieve pressure if the part fails.
Look at each of these, they should all be flat on top.
Any showing a bulge are dying or already dead.
If you or a friend have any soldering skills, this block, the power supply, can be removed from the mounting for repair.
The parts that fail are cheap but will likely fail again due to a design flaw or just lousy parts.
This can be often prevented by adding (under the board) a multi-layer ceramic capacitor with a value of 0.1 to 0.47 uFd parallel to the replaced capacitor. Voltages on these will be 50 VDC or lower and anything above 25 VDC will be fine.
This will protect the chemical (electrolytic) capacitor from trying to deal with high frequencies which cause this kind of failure.
Good luck-
Posted on Nov 20, 2014
I have a 42 in. HD TV, it turned itself off, and when i turned it back on the screen is all pink and white
Try unplugging it and letting it sit for 5 minutes or so and see if it resets itself.
May 27, 2012 | Televison & Video
Samsung ln55a950. There are black horizontal lines that start of strongest on the very right of the screen and fade to gone at about the middle. The lines are maybe 3 pixels tall before fading, but they...
I have similar issues with my Samsung TV model LN55A950... all I did was take the back cover off...unplugged the two wide ribbon cables of the panel from the T-Con board, then turned it on...I waited for a minute until everything normalized. at first, all i see were similar lines...horizontal pin stripes on white background...white background because the panel is not connected to any image source. Then all lines are gone, after the 'normalization." you should only see white all through out. I then turned the unit off...connected the two cables back, turned it back on...voila! my TV is back to normal viewing, no more lines!!!
Jul 06, 2011 | Samsung LN55A950 55 in. LCD TV
My TV is almost 5 years old. Barely used more
Howdy,
Sounds like the TV has lost the VIDEO and only has color. Make sure all the cables are secure and good. 2) Reset the TV by unplugging the TV or any BOX you have attached to TV. Unplug both from a/c for 3-5 minutes, plug back in and turn both on.
If no fix. Go to service Company that is Authorized and get an estimate, possible cost $450.00 +. Too many areas of concern to help you with particulars.
Good Luck, Big Irish.
Dec 02, 2009 | Hitachi 46F500 46" Rear Projection...
TV picture compressed top and bottom, then turned itself off
hi i think you have trouble on the power supply section.
Aug 24, 2009 | Televison & Video
How do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
Jul 08, 2009 | Vizio L32 32 in. LCD HDTV
Tv will not stay turned on
its a problem in your main board of the tv.
Oct 30, 2008 | Mitsubishi WS-55807 TV
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Can you help
this could be a loose LVDS cable, or the T-con board
Jul 17, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Televison & Video Logo
51 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
