Question about Health & Beauty
How do i update clock? - Health & Beauty
  • kakima Nov 20, 2014
    What make and model?
Ironman GPS defaults to incorrect clock info after online update
Maybe you should finish second update since is interupted?
Feb 12, 2018 | VIA Computers & Internet
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
How do I set the clock in my 2006 Equinox... nothing in the manual
check page 3-39
Setting the Time
symbol will appear on the audio display and the hour
number will flash. Then turn the ADJ knob to increase or
to decrease the hour. To set the minutes, press the
clock button again. The minute numbers will flash.
Then turn the ADJ knob to increase or to decrease
or off.
release the clock button to enter the clock set mode,
until UPDATED appears on the display. If the time
is not available from the station, NO TIME UPDATE will
appear on the display.
RDS broadcast station, it may take a few minutes for
the time to update.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 30, 2010 | 2006 Chevrolet Equinox
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
How do I change the time on the radio in my '08 pontiac g6
To set the hour, press the CLOCK button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the CLOCK button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Nov 07, 2010 | 2008 Pontiac G6 Sedan
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Oct 23, 2010 | 2002 Chevrolet Impala
How do I set my clock in my 2005 CTS?
  1. Press the TUNE/SEL knob to enter the main menu
  2. Turn the TUNE/SEL knob until set clock appears on the display
  3. Press the TUNE/SEL knob to select set clock
  4. Turn the TUNE/SEL knob to adjust the time
  5. Press the TUNE/SEL knob to update the time.Time updated will appear on the display
Thank you for using Fixya and good luck.
Mar 16, 2010 | 2005 Cadillac CTS
Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
Oct 26, 2009 | Timex T311T Clock Radio
Update time
What timer? what clock? This one doesn't have a clock or a timer. There are backlight timer and powersave features that operate in 5, 10, 15, 20 min increments, etc. but there is no clock.
Here is the complete user's manual for full details:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
Jun 09, 2008 | SanDisk Sansa Clip MP3 Player
Clock will not adjust properly
Inside the PC is a small lithium cell battery that may be going bad. Or, check for updates on microsoft update to get the clock settings where they need to be. Also check in your settings that you are set to the correct time zone.
Apr 07, 2008 | HP Compaq Presario S3040SE (DF222AR#ABA)...
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
