Acer aspire E1-731-4699. When power is turned on it blinks the home screen and then a blue screen with a flashing icon. Tried pushing buttons to reset but no luck. Any ideas?
  • Dave Campbell Nov 20, 2014
    Hi Kelly Woodard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    - What operating system? (WinXP Win7 etc.)
    - When did it last boot up correctly, and were there any issues with it when it did work?
    Sergeant:
    Champion:
  • 239 Answers
Try starting it with a linux live cd in the DVD drive, I would suggest mx14 - if you can run a system from a cd then you may be able to access your hard drive and copy off your personal stuff that you need. (You may need to change the boot order by entering the bios when the laptop starts - try 'esc' or 'F2' as the laptop starts - go to boot order and set dvd drive as first boot. F10 to save and exit)
If you can do this then there is a fault with the instructions for the operating system. If you have a boot CD for the system then start the laptop with the CD in the drive.
If not then you can purchase one from here
https://neosmart.net/blog/windows-recovery-discs/
Download mx14 from here
http://www.mepis.org/mirrors
Posted on Nov 26, 2014
  • 163 Answers
SOURCE: My Dell Inspiron 1150 PC Notebook Won't Turn On
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Posted on Jan 15, 2008
  • 217 Answers
SOURCE: Acer Aspire 3050 blue screen
When you first power your computer on, you'll want to press F2 to get into the bios. If you're lucky, your bios will have the option to turn off the Automatic Restart on System Failure. It may be worded differently, but if you can turn that off, then you'll be able to see what your blue screen says.
Also, if you have your Windows XP cd (if that is your operating system), you'll want to boot up with the cd in your drive, to get to the XP Recovery Console. Run the command: chkdsk /r
(It takes about 30+mins to finish)
It will scan and repair any errors it may find on your hard drive.
Posted on Jan 28, 2008
  • 1019 Answers
SOURCE: Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Posted on Feb 24, 2008
  • 7 Answers
SOURCE: Acer Aspire One hangs during boot and then powers off after 30sec
sounds to me like you need to restore your bios settings to default. if you can get into bios usually by pressing delete then it shouldnt be too hard. if that dont work the next easiest thing to do is to take out the battery that is inside the laptop somewhere on the motherboard! this will clear bios settings after about 2 or 3 mins of being out make sure the computer has no other power going to it when you take out battery
Posted on Feb 17, 2009
SOURCE: Eee Pc 701SD/linux. No icons appear at startup, just blue screen
Try opening a terminal (Ctrl+Alt+t) and type the following:
sh startsimple.sh
and press enter. It worked for me, hope it will for you!
Posted on Dec 12, 2009
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
My acer aspire 5742 while pushing power button,the only thing it does is the blue light on and the cooler and nothing else... please heeeelp...
Does the battery charge light come on? Does the HDD LED blink? You get nothing on the screen at boot? Remove and test the HDD, reseat the Memory Mods. Have you tried a system restore/recovery?
Feb 20, 2013 | Computers & Internet
Hi, when I turn on the Acer Aspire 5920, the acer screen comes on, the bar across the bottom moves, then it goes to a blank dark screen with a blinking cursor. I have tried turning off and turning on and...
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
Mar 19, 2011 | Acer Aspire 5920-6727 Notebook
My acer aspire 4315 laptop screen goes dark
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
http://blog.shimpossible.com/2007/07/18/white-screen-of-deat­h/
Mar 05, 2010 | Acer Aspire 4315 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
Jan 19, 2010 | Acer Aspire 4315 Notebook
My ACER Aspire One ran out of battery power so it was plugged in to recharge and left alone for a couple hours. When I returned to it and tried to turn it on...nothing. The green power light comes on and...
You can find the BIOS download here:
Jan 17, 2010 | Acer Aspire One PC Notebook
My Acer Aspire One shows black screen only.
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9' Won't Boot Up !!!
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This is also known as crisis disk mode.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, with the flash drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS. After a while the button stops blinking, and the AA1 reboots shortly after. Wait patiently.
If it doesn't reboot by itself, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
