Question about Homelite Garden
How do i remove sprocket from chainsaw homelite ut10588
Need to replace sprocket can get sprocket off shaft. took nut off end where pull string is. still can't get sprocket off
  • Eugene Rounds Nov 20, 2014
    Hi wayne e solomon, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Also check for a chain brake as a few of these had them and if it has one make it is released.
  • Homelite Master
  • 1,169 Answers
The washer needs to removed too as it may have dropped into a thread. Other than that there nothing that shouldn't be anything holding the sprocket drum; unless you have a clutch or needle bearing failure.
Note: only 6 tooth .375 sprocket is available and than it is an aftermarket one. The 8 tooth .325 spocket is no longer available.
how do i remove sprocket from chainsaw homelite ut - 25291260-v1cohf4wp5zvrwa3m3w0ss1q-2-1.png
Posted on Nov 20, 2014
How to remove sprocket from chainsaw ut10588
Also if yours has a chain brake make it is in the release position. A few of these saws had them but not all.
Nov 20, 2014 | Homelite UT10580 18" Gas 42cc Chain Saw
HOW DO YOUREMOVE THE SPROCKET
The P4018 has an out board sprocket, so to remove you need to remove the side cover nuts and take away the cover, the bar and the chain, there is then an e clip on the end of the crank, insert a suitable screw driver into the inner edge of this clip and gently pry off, take away the large backing washer, the sprocket will now just pull off the crank.
Jan 13, 2013 | Poulan P4018wm Wildthing Chainsaw Wild...
Races at idle
If the idle cannot be controled by the idle screw ( screw marked with an I or T on the side of the carb ) then you may well have an air leak through a crank seal or a gasket.
Nov 23, 2012 | Homelite UT10580 18-Inch Gas 42cc Chain...
Motor runs, but chain does not move
check to see if the chain is on the sprocket to do this you will probably have to remove the side cover on the saw if chain is on sprocket and still will not move then you may have a sheared key in the key way if this saw has one, if it does you should be able to see the key way on the end of the shaft coming out of the motor. there should be a nut that holds the sprocket in place if that nut is loose and the shaft is splined instead of having a key way the the sprocket could slip while the motor is turning.
Feb 25, 2011 | Remington Electric Chain Saw
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Need instructions on how to replace a chain on Homelite chainsaw
Remove the drive end side cover after releasing the chain brake if it exists and removing the mounting nuts. The bar should slide back and allow the old chain to be removed. Take out the bar and clean it's oil passages including the two small channels that go out to the chain groove. Clean the entire chain groove. Clean the motor case side where the bar fits to. Run the motor for a few moments to see if oil oozes out of the side port. If ok, reinstall the bar and push back. Thread the new chain over the sprocket, then work it over the bar making sure the bottom run of chain cuts toward you. Pull the bar outward. Replace the cleaned cover making sure the adjustment tang drops into one of the large holes in the bar--you may have to back out the adjustment screw several turns. Replace the mounting nuts finger tight and adjust the chain until it pulls the lower run of chain up to the bar, yet you can still pull the chain by hand. Tighten the bar nuts firmly and recheck the chain tension. Check for proper oiling by running the saw tip near cardboard for several moments--it should leave a thin line of oil on the cardboard. Hope this helps!
Jun 18, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I lost my manual and need to change the chain on my homelite chainsaw... never had one of these before... stihl and husky are pretty straight forward... this one not so much...
Turn the chain brake off, then remove the side cover (back off the adjustment screw several turns first). Clean the oil ports in the rear of the bar and the area around the oil outlet port. Fit the chain to the sprocket, then work the bar into the chain and pull the bar outward to tighten the chain. Fit the cover back making sure the adjustment tang drops into the large hole in the bar. Run the mounting nuts up finger tight, adjust the chain so that it doesn't droop from the bar, but allows the chain to be turned by hand, then tighten the nuts and recheck chain tension. Hope this helps!
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
52 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
