Question about Homelite UT10580 18" Gas 42cc Chain Saw
<!-- from fixya rte -->How to remove sprocket from chainsaw ut10588 - Homelite UT10580 18" Gas 42cc Chain Saw
  • Homelite Master
  • 1,169 Answers
Also if yours has a chain brake make it is in the release position. A few of these saws had them but not all.
Posted on Nov 20, 2014
How to remove sprocket and clutch from ms250 stihl chainsaw
Removal>
  1. Remove the clutch drum/chain sprocket
  2. Remove the air filter
  3. Take out the shutter.
  4. Pull boot off the spark plug.
  5. Unscrew the spark plug.
  6. Close the decompression valve, if fitted.
  7. Push the locking strip 0000 893 5903 into the cylinder. (Piston Stop)
  8. Unscrew the clutch from the crankshaft clockwise (left-hand thread).
Installation>
  1. Screw on the clutch and tighten down to 50 Nm (37 lb.ft).
  2. Install the clutch drum / chain sprocket .
  3. Remove locking strip from the cylinder.
  4. Insert spark plug and tighten down to 25 Nm (18.5 lb.ft).
  5. Fit boot on the spark plug.
  6. Fit the shutter so that its lugs engage the recesses in the handle housing.
  7. Install the air filter
Feb 22, 2015 | Garden
How do i remove sprocket from chainsaw homelite ut10588
The washer needs to removed too as it may have dropped into a thread. Other than that there nothing that shouldn't be anything holding the sprocket drum; unless you have a clutch or needle bearing failure.
Note: only 6 tooth .375 sprocket is available and than it is an aftermarket one. The 8 tooth .325 spocket is no longer available.
Nov 20, 2014 | Homelite Garden
HOW DO YOUREMOVE THE SPROCKET
The P4018 has an out board sprocket, so to remove you need to remove the side cover nuts and take away the cover, the bar and the chain, there is then an e clip on the end of the crank, insert a suitable screw driver into the inner edge of this clip and gently pry off, take away the large backing washer, the sprocket will now just pull off the crank.
Jan 13, 2013 | Poulan P4018wm Wildthing Chainsaw Wild...
Races at idle
If the idle cannot be controled by the idle screw ( screw marked with an I or T on the side of the carb ) then you may well have an air leak through a crank seal or a gasket.
Nov 23, 2012 | Homelite UT10580 18-Inch Gas 42cc Chain...
How do remove mac 3200 chainsaw sprocket
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 08, 2012 | McCulloch Chainsaw Sprocket Model Mac...
Unstick valve in chainsaw
make sure that the chain is not to tight then remove the chain and try to move the sprocket by hanh
Jun 22, 2012 | Garden
How do you replace spur sprocket on a 038ab stihl chaninsaw? how do you remove the sprocket that is over to the right of the spur sprocket?
To remove the sprocket on this saw you must remove the oiler gear that sits in the way. Remove the mounting screws for the oiler gear plate and you are home free.
I hope it helps
look for parts at a local dealer like www.arcolawn.com
joe
Feb 03, 2011 | RTO Spur Sprocket For Stihl 017, 021...
Broke tooth on chain drive sprocket. whats the easiest way to get it apart to put on new one
Standard procedure for removal of the drive sprocket on the saws i work on are
release the chain brakeremove the sprocket cover... bar & chain clean all that sawdust and oil mud with brake cleaner and or bristle brushremove circlip with a flat head screwdriver and a prying motion* find circlipremove spur or rim sprocket Replace in opposite order.. being sure to align the chain speed driven oil pump with the notch in spur sprocket if equipped(some arborist saws require a piston stop to remove the clutch before you can remove the spur) BUY A STIH AND TALK TO YOUR DEALER.. THEY ARE FULL OF INFO AND VERY HELFUL
Jan 12, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Homelite UT10580 18" Gas 42cc Chain Saw Logo
50 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
