Question about InFocus Office Equipment & Supplies
Infocus 3916 Projector goes in and out of focus. It is a little less than 2 years old. Any suggestions for a solution?
We have tried switching out connector cables. The lens appears to be in fairly good shape and is not scratched enough to cause issues.
    Sergeant:
  • 320 Answers
Many of these projectors have a manual focus, and an auto focus. Make sure the auto focus is turned off in the menu options.
Then make sure the manual focus is not moving on it's own from vibration of the cooling fan. You can check this by manually focusing the projector, then taking a marker and marking a line on the focus wheels. If the projector goes out of focus, check the line you made and see if it has moved, if so. Your projector is going out of focus from vibration of the cooling fan, or the surrounding environment.
If your projector is mounted to the ceiling you can add a couple of rubber washers between the projector and the mounting bracket to cut down on vibration.
If your projector is sitting on a desk / table / ground, you can use foam padding to keep it from vibrating.
another solutions would be to temporarily tape the adjusting knobs while the projector is in use.
If your projector has a protective cap that is put on the lens when not in use, this will also push the lens out of focus, and will need to be re-adjusted each use.
Posted on Nov 20, 2014
SOURCE: IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Posted on Jan 23, 2008
HDTV GURU
  • 261 Answers
SOURCE: lp335 in focus projector lamp not turning on; spark switch gap is sparking
It could be the lamp. I have seen this many times on DLP'S. If the ballast is firing it which is usually around 600 volts or so, then i would say it is fine, and only needs a lamp. Let me know if that helped you. Later Jay
Posted on Jan 31, 2008
  • 26 Answers
SOURCE: Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Posted on Mar 13, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus IN24 projector picture shaking
reset the settings to factory default and make sure the resolution matches. if it persists, replace the colorwheel.
Posted on Dec 01, 2009
  • 269 Answers
SOURCE: My projector has little white dots that appear on
Take off the front bezel, then remove the screws from the lens,pull the lens out and blow it out with compressed air. Do not touch the mirror or magnifier inside. If this doesn't get all of the blemishes, then you will have to remove the top cover and then the top silver part of the engine and blow it out from the top.
Posted on May 06, 2010
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
InFocus Won't turn off, no powering down, and no projection
The 4805 does not have a power button it has a power switch next to the mains power connector but that switch has no lights near it.
If you meant the power light on the top of the projector right next to the menu button is yellow that is bad. it indicates that the main board is not working which would explain the projector always being on. also the led being orange means that both the green and red led's are on at the same time (this is BAD)
This is not a valid function for the led's. Another indicator that the main board is wacked. By the way if you received the projector less than 30 days ago you can file a claim with the eBay resolution center that the projector is not as advertised/Described in the listing. And you might be surprised when you get your money back! the "NO RETURNS"is null and void if there was any gross misrepresentation or deception in the listing!! i.e. Not as described...
Sep 19, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
My 7205 has developed a thick black bar (rectangle) horizontally across the middle of the screen. It shows on all inputs and even on the intro Infocus screen. Does anyone know the cause please?
if the black bar has fuzzy rainbow edges, the light tunnel has collapsed and needs replacement. if the image has solid edges (to the pixel), there is a problem with the dmd chip. the tunnel is under $15 and can be replaced with some ease, but the dmd is the image chip and is quite pricy.
Jul 18, 2009 | InFocus ScreenPlay 7205 Multimedia...
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Replacement or buying a new one?.
Hi, this seems to be lamp only, go the menu setup and press service info : then you get the lamp hours used if it is more then 1500 hrs you must change the lamp if less, try cleaning filter then reset the lamp again. if problem persist. lamp has to be changed.
Jan 27, 2009 | InFocus IN72 Multimedia Projector
In Focus IN72
The capacitor that is blown wouldnot be a 150V but a 450V. Dannol, I think you should really double check that as you most probably could be wrong or it most probably is a typo error.
The correct capacitor is a 104K450 NIS T83. 100nf (0.1uf), 10% tolerance and 450V rad polyester type.
Jul 23, 2008 | InFocus IN72 Multimedia Projector
InFocus LP650 will not come on
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
89 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
