Question about Keurig B40 Coffee Maker
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn't need descaling or cleaning. How can I adjust the amount of water to be dispensed?
    Master:
  • 249 Answers
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Posted on Nov 26, 2014
  • 9 Answers
SOURCE: My Keurig one-cup coffee maker
There is a post on descaling already but I think the unit just doesn't have enough water in the resevoir. See several of my other posts on how to fill the machine.
Posted on Mar 05, 2009
mcdevito75
  • 1970 Answers
SOURCE: will not made medium cup of coffee. Makes only
mcdevito75 here, Sounds like a defective machine, Hope you had warrantee. Contact Keurig online or phone, thru the owner manual.
Posted on Jun 28, 2010
SOURCE: Our Keurig only dispenses a partial cup of coffee.
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Posted on Dec 02, 2010
heatman101
  • 43501 Answers
SOURCE: Using a Keurig Platinum coffee machine and water
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig has three settings
heatman101
Posted on Mar 01, 2011
My mr.coffee keurig model VBMC KG5 single cup coffee maker will not run a whole cup during cycle
The Keurig machine operates by pumping air into the glass boiler to drive the hot water through your coffee cartridge. When you have put a new cartridge into the dispenser, you select a size of cup. When you press the go button, you should hear the machine pump water into the boiler to the requested cup size (test by selecting large size to hear the pumping work). Next the machine operates an air pump to force the specific amount of hot water through the cartridge and make the cup of coffee. The problem encountered with these machine is that a small amount of water can drip internally onto the air pump and it will either not operate or work intermittantly. There is a great 'how to fix' video on utube concerning the Keurig-taking apart and fixing.
Honestly, I don't know whether this is your problem, but I do know this happened to a machine I had. You should hear the tiny air pump working when the cup of coffee should be brewing. You can laboriously take apart and replace, and given the price of these units it may be practicle to do the repair. Watch video on utube--its like three or four parts and very instructive. Sorry I don't have the link.
Jan 09, 2014 | Keurig Platinum B70 Coffee Maker
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
Will not made medium cup of coffee. Makes only small size. Large size comes out medium size and watered down in potency.
Jun 28, 2010 | Keurig Special Edition B60 Coffee Maker
Coffee maker doesnt **** water out to begin making the coffee. No sounds at all and you cant select a cup size.
The air pump needs to be replaced. You can have it repaired or purchase the part yourself. The problem with B40 machines is that they are difficult, if not impossible, to open w/o cracking the casing. Call Keurig to sell it for scrap and get a discount on the next machine. The B-40 is being replaced by the B-44
Nov 07, 2009 | Keurig Elite B40 Coffee Maker
Keurig B40 Coffee Maker Logo
558 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
