The machine do not spin !
Check the belt it's ok. The pump works fine.
    Sergeant:
  • 271 Answers
NAME AND MODEL NUMBER OF THE MACHINE WOULD HELP.
Posted on Nov 20, 2014
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Machine not spinning out comes up error7 it is a haier hns 1460 tve model , pump is filling up and emptying drum ok , took back cover off belt and spider both fine drum turns if you turn belt what could be...
Check lid switch.
If you have wash action from then the motor is most likely O.K.
If your lid switch is faulty, the machine stops before the spin cycle.
Ash
Oct 21, 2009 | Haier Washing Machines
My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Aug 23, 2009 | GE Profile WPSR3100W
No spin cycle or drain
Ok, check the following before you replace the timer. in most cases, the washer will not spin if there is a drainage issue. please check the following below and, if everything concerning the drain assembly checks out ok, then , replace the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 05, 2009 | Frigidaire Washing Machines
Does not complete spin cycle
Ok, when this happens, its usually because of a drainage issue. the spin cycle has to work in conjunction with the drain pump to remove the water during the spin cycle and, if there is a clog or drainage issue, the spin cycle will shutdown. check the following to address this drainage issue.
2. Water Pump
Jun 01, 2009 | Frigidaire Washing Machines
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Won't spin - belt fine!
I had the same problem with my Bosch 2060, which is almost 6yrs old. After opening the back of the washer and inspecting, belt looked good and not loose. Spending several hrs on net looking for postings, most thinking replacement of motor brushes is the solution. Someone posted that the connector on the right side of motor (located under the tub) to the right side could be loose. I pushed on the connector to make sure it was tight. Powered up and went to spin cycle and was greatly relieved that washer began to spin. Thanks for whoever posted this simple fix.
Jan 07, 2008 | Bosch Axxis WFL 2060 Front Load Washer
No Spin Cycle
Is the belt OK? Are you sure that the pump is working fine and not plugged up with a sock or something? Is ALL the water being pumped out by the pump or is it just minimumally flowing out via gravity? What's the timer doing?
I'm at rdarnell@btes.tv if you need more help.
Dec 16, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing machine say NO!
because of what you say about it feels like it is exploding on spin cos too much water, suspect it may be drain pump. check filter is not blocked. check no foreign object stuck in pump - bits of bra wires are the favourite
Nov 17, 2006 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
