Question about Kelvinator Refrigerators
We have a Kelvinator Model MRT15CRADO Refrigerator, Serial #BA35003331. We are planning on moving and the last time we moved we had to push a "Re-Set" button to get it working again. Can you tell me
Where is the Re-Set Button?
    Sergeant:
  • 244 Answers
For online Kelvinator product support, access the manufacturer's library >
Kelvinator Customer Support: 866-738-1640
Posted on Nov 20, 2014
SOURCE: ICEMAKER
95% of the time the problem is with the water valve on the back of the fridge that supplies water to the IM. I would verify first if this is your problem. It is a part that often fails and is quite common occurance.
Posted on Dec 10, 2007
22yooper
  • 828 Answers
SOURCE: ge profile refrigerator won't run
Where is the click sound coming from. There is no fuse in the unit. If light comes on you have power. If it is a frost free refrigerator it will not come on if the defrost timer is in the defrost position. There is no reset button. Did you wait about 20 minutes to see if it would come on by its self?
Posted on May 23, 2008
  • 864 Answers
SOURCE: Unplugged our refrigerator to move it. now it doesn't cool. Is there a reset button?
If you tipped it on its side you may have caused an air bubble to form in the refrigerant.
Plug it in, leave it empty, set for maximum cooling and do not open the door to check it for several hours.  Put a thermometer inside to check the actual temperature after three or four hours to see if it is getting cool.  Listen for the compressor to come on and whether there are any strange noises.  If you hear gurgling in the coils the refrigerant should be working OK.
Posted on May 20, 2009
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
SOURCE: MY LG fridge model GR- M562 YLY
I am in search of an LG PCB board LBN 22515sb
Posted on Sep 10, 2009
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
How to set time on model HD211B clock radio
1: Remove screw from top back of radio and carefully lift lid that retains buttons. Might be a good idea to take a pic of buttons so they don't get mixed up as they will just pop off at this point.
2: On either side of the back middle button you will see a switch and three (3) buttons.
3: Move "Off On Lock" switch to "Off" (left) position. You will see the unlocked symbol appear on the display.
4: Push far right button first to set your time "Zone" using the "Alarm Time" or "Radio Tune" buttons. Wait 5 seconds for the beep when done.
5: Push the "Time Set" button. (It is the one closest to the "Off On Lock" switch).
6: Use the "Alarm Time" or "Radio Tune" buttons to set the time. (Note: "PM" will appear in the upper left corner of the front display when your time is after noon!)
7: The time display will stop blinking and set about 8 seconds after your last move.
8: Push "Calen" button to set calendar. First the year the push the button again to scroll to the date.
9: Push the lock switch to the right and the lock symbol should disappear from the front display.
10: p
If you removed any buttons put them back, then put the cover back on and re install the screw.
or
Call the front desk and ask them to set or replace the clock.....
Oct 17, 2012 | Audio Players & Recorders
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
How do you level a kelvinator refrigerator
Most refrigerators have adjustable feet, both front and back. Some you'll need a couple of wrenches. There may be a locknut that holds the adjustable 'foot' in place: loosen that first, then take the weight off the front of the refrigerator, either by having someone push on it, or by using a large prybar. Adjust the foot down by unscrewing it a few turns. Repeat for the other front foot. Once you've got the feet adjusted where you want them (so that the refrigerator isn't leaning, and also is supported solidly on the floor) tighten the locknuts on the feet. If your floor is too far out of level, you might have to pull the refrigerator out and and adjust the rear feet in (if it has them). Worst case, you may need to get a / some thin pieces of plywood to shim up the front (only as a last resort).
Nov 23, 2011 | Kelvinator Refrigerators
I need to have a copy of the manual of this type of kelvinator refrigerator
Look up the manufacture on the net and input model and serial # it should come up or look at a local co. that sells that model and talk to the sales person.
May 10, 2011 | Refrigerators
I have a new invicta watch model number 6089 that I just recived yesterday. I can set the time and date but for some reason I can not set the 3 arm?? I have read the instructions and still it will not...
The trick to setting the 24hr hand on the 6089 is to pull the crown out only one notch (not two) before using the upper push button to change the time. As it's a 24hr hand, the best time to set it is at the top of the hour.
Feb 05, 2011 | Invicta Watches
Top freezer - not freezing - thermostat dial for cooler - no change when moved to colder. do not hear a fan or compressor turn on - of course lower not cooling either. (frigidare) model #...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Frigidaire Refrigerators
Refrigerators Logo
114 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
