Question about Ricoh Office Equipment & Supplies
How do i power on Ricoh 700 machine?
My Aficio Ricoh 700 power is not on. when i insert the power plug in the socket machine is not on pls tell me the solution
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 884 Answers
Hi
You can find a manual for your machine in pdf format which can be saved to your computer for future reference here:
http://www.parsancopy.ir/downloads/aficio700.pdf
A quick look indicates that there are two switches on the machine that need to be on - Items 5 and 8 on page 4 of the manual, page 20 of the pdf - it might be a silly question but have you checked that these switches are both on. One would not normally expect a machine like this to power up just by plugging it in.
If the switches are on, then you have a more complex problem which will be reported on the control panel.
To find out more about the problems you can download a service manual from here:
Download Service Manuals for free
and then clicking on the "Ricoh-1903.pdf" link.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 20, 2014
Soulvisitor
  • 1113 Answers
SOURCE: Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Posted on Nov 30, 2007
bowdo
  • 78 Answers
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
SOURCE: Ricoh Aficio FX10 Fax/copier
I called the Ricoh 800 number at 1-800-577-4264 and they found me a local tech to fix the problem it is a motor/or part proble code try the number and they can help you out.
Posted on Mar 31, 2008
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Posted on Mar 02, 2009
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
My machine Ricoh 700 power not on?
make sure all the compartments are closed fully and covers all closed.
Nov 20, 2014 | Ricoh Office Equipment & Supplies
I have a Ricoh Aficio 2500sp copier, a paper got jammed which was released and i closed the door at the side (as normal) the copier stop working as though a fuse went...... Ive checked the plug, socket and...
check at the back of the machine, somewhere around the power cable, there should be a small black trip switch, if that doesnt work then check the fuse on the power supply board after you unplugged the power cable
Nov 03, 2013 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
SC 548 on ricoh aficio 2022
Hi Andreas: The fusing unit has not been reinstalled properly. There is a receptical on the back of the Fuser that mates with a plug in the machine when you install the part. the machine is telling you it did not detect the fuser. Undo the screws and remove it and reinset it again, makin sure that it seats properly. then you will need to reset the code. Go into SP Mode: Push in sequence; Clear-107-red stop button(hold this down until display changes and shows "copy etc"), turn machine off(using red power switch, wait 10seconds and turn back on. If you still get the error code the fuser still is not inserted correctly. Hope this helps.
PS: Black spots can also indicate a new drum is needed. It may have a small chip in the surface.
Regards
Munybuny
Jan 22, 2009 | Ricoh Aficio 2022 Black and White Copier
"Reset fusing unit"
Please open the front door and in the middle you will find a brown cover. Unscrew the screw of the cover and pull out the fusing unit.
Push it back carefully, close the front door and switch on.
If reset fusing unit is still there, probably the socket at the rear of the fusing unit is out of place. If it is Ok, then there is the plug mounted at the back in the machine which is out of place.
It will need to remove the power supply unit from the back, to be able to access this plug and adjust it.
Good luck.
Jan 09, 2009 | Ricoh Aficio 180 Laser Printer
The function key
hi whats the SC code showing up?
May 27, 2008 | Ricoh Aficio 250 Copier
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
