Question about Ryobi Garden
Brand new Ryobi 2-cycle backpack leaf blower. It will not run full throttle. Should I take back and get new one or ?
Bought a Home Depot. It seems to not be getting enough gas/oil and dies at full throttle.
    Sergeant:
  • 322 Answers
Take it back. If the new one doesn't perform like it should get your money back and buy a Stihl. They will fuel and run the machine before you ever leave the dealer with it to make sure it runs like it should and they can answer any questions and even get you parts. Husqvarna may do the same thing
Posted on Nov 21, 2014
  • 40 Answers
SOURCE: Ryobi RBL30MVA petrol blower problem
if this is a brand new I would ask is the gas oil mixture fresh and of the proper ratio. most use 40-1
if this is not brand new look and see if the muffler could be clogged up. a common problem is the spark arrestor screen gets clogged up with carbon deposits.
Posted on Mar 11, 2009
  • 246 Answers
SOURCE: Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Low RPM's Ryobi 25.4 cc backpack blower
you need to adjust the carbarator
Posted on Sep 18, 2009
bbreton
  • 437 Answers
SOURCE: My Homelite backpack leaf blower only idles. when
Is the new gas some you just mixed up from the gas station or is from the can in the garage? If it is indeed fresh then you are looking at needing the carburetor adjusted. Sorry you can not do it yourself, The epa only allows qualified technician to adjust them. Plus the tool to do so are not available to the general public.
HTH
Good Day.
Posted on Oct 31, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the gas;oil ratio for the echo 403T backpack leaf blower.
50 to 1
Posted on Nov 01, 2009
Ryobi blower stalls when not at full power
there is a gasket right under the prime plug most likely that is bad
Sep 20, 2012 | Ryobi Garden
Craftsman 32 cc 4-Cycle Backpack Blower won't throttle
I wouldn't try too hard to fix ANYTHING that's brand new! This is what a warranty is for!
May 31, 2012 | Craftsman 32 cc 4-Cycle Backpack Blower
Ryobi Backpack Blower Elbow
the home depot stores sell ryobi so i think they might have it if not they sure can get it for you, or you can always go to the ryobi website and try purchasing it that way.
Jan 23, 2010 | Ryobi Backpack Blower 25.4cc
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 03, 2009 | Ryobi Backpack Blower 25.4cc
Backpack only runs low RPM, especially when cold.
Your carbeurator is gummed up. Remove the old fuel and make up a new fuel mix with new gas from the gas station. Then get a can of carbeurator cleaner spray. Three short squirts in the air intake and let it run. Three more squirts every minute or so until you dissolve the partial blockage that is causing your problem.
Jul 28, 2009 | Ryobi Backpack Blower 25.4cc
My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Jun 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas blower idles fine when i push the throttle it stalls
some carbs are not adjustable,check your air filter first to make sure its not rescricted and also a new plug,make sure your fuel is fresh,now if you do have adjusting screws,most have plastic caps on them with preset adjustments locked in,you will have to remove these caps to adjust,they need not be reinstalled,Hope this helps
Jun 09, 2009 | Ryobi Backpack Blower 25.4cc
Someone ran gas instead of 2-cycle in leaf-blower; now locked up
It's probably dead. If the rope won't pull buy another and keep it for parts, the repair bill will be more than it costs. Spray some wd- 40 in the spark plug hole and let it sit for a couple days, IF it frees up you got lucky but don't expect it.
Mar 11, 2009 | Ryobi Backpack Blower 25.4cc
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Garden Logo
226 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
